2F Heritage!??!?
My dad has like 2 of those old Chevy 235's in his garage one in his 39 Chevy coupe, which might be a bit smaller cid wise.
They are quite similar to the F, 2F's I've had there over the years.
Still have to say, America dropped the ball, many have poor work ethics here and take no pride in their work, more concerned about that beer their gonna drink after work, whatever game is in TV land.
They may have originally copied us, but detroit has since attempted to copy them and failed.
No new ideas here.
I know the GM hei ignition I swapped in only required me changing the gear, and machining down the "stop" on the shaft. Works great. I've heard that the oil pumps are interchangeable as well?
Fork lifts
Did you know that the 2F engine was used in other apps? We have 2 old toyota forklifts at work that both have the 2F engine in them. Looks strange to see one in a lift. Funny thing is I am the only one who can start them on a cold day.
Go :beer:
I thought the chevy six was great engine? why so blue? just like the ford 300 six, another great engine. who needs flat powered V8's?
Mark W said:
Chevy 235 uses solid lifters. You can interchange them with the 2F. I've done it, and encountered engines where someone else has.
No reason to swap them, but it can be done.
Mark...
Are they cheaper than the Toyota ones?
Mark...
Hey Mark W I am trying to price out a set, but the parts guy wants to know if they are from an engine with a power (or is it super) glide transmision. Do you know? I have bought lifters from Toyota for $35 a pop and don't want to again. My ports guy said he sold some 327 solid lifters for $7 a piece yesterday.
clemson55 said:
Toyota's founder was originally a textile manufacturer or something of that nature.
Actually they made looms for the textile industry. I think the name of the company was originally Toyoda Automatic Loom Works. If that's not the exact name, it's close. I don't have the "50th Anniversary of the Toyota Land Cruiser" book in front of me. Maybe Land Pimp has it handy.
Pretty sure all major japanese auto manufacturers were in the loom business at one time.
snailwagon said:
I was also always under the impression that toyota originally copied general motors. However, Even though gm made a decent straight six, expecially for the time, the reliability isn't the same as toyota. Really not a big deal since toyota has diverged so much upon their original design. Ever see a chevy run for 300000 miles on the same engine? The answer is likely no.
Yeah, I have an '85 suburban with over 400000 miles on it....and it still runs perfect!.....And its never been babied either....lots of towing, off-raod, ect.....all stock.....................................................that is the reason i put a chevy in my 60!
I couldn't tell you. I don't play with old (obsolete) chevy sixes. Just old (obsolete?) Toyota sixes. ;)
I originally came across them in a couple of the engines I have worked on. Afterwards while chatting with my machinest I realized what they were from and my cam grinder later confirmed it. But I have no idea what drivetrain they would have come with. I have a little trouble believing that it would make any difference . ???
Why don't you just get a set of reground lifters?
Mark...
New lifters for $110 is a great price. In line with the usual price for regrinds.
AFAIK Specter and MAF sell reground lifters. I wouldn't be surprised if JTO had some. Check around. I normally have some on hand myself but I just sold the last cam/lifter set that I had here. If you find an operation that regrinds cams they do lifters too. Very cheap. if you send them you own lifters (unless they are too trashed to recondition).
Mark...
I had some lifters reground (10 good ones I could find) and replaced the cam a couple years ago. I have the engine out right now and it looks like I have some wear on the reground ones. The two I got from Toyota look cherry. The cam looks good too. Most of the used lifters I have seen have been trashed, however I haven't been into as many engines as you have Mark.
I agree that I have never seen a set of used cam/lifters that I would swap into another engine,or in most situation reuse in the same engine either. So far I have not had any complaints about the longevity of regrinds though.
Mark...
Mark...
Hmmm...
What do you think about these?
Pulled the cam and lifters to reseal my front plate.
These have probably 20k on them...
I thought they were supposed to spin around, but it doesn't look like they are.
I agree. That picture doesn't look like the lifter is spinning like it is supposed to. From that picture it looks fubar. I haven't seen that happen before. How 'bout another shot or two with different lighting angles?
Mark...
Mark...
Almost looks like it isn't centered on the cam lobe.......as if the cam gear has begun to walk off the cam.... was the snapring still on the end of the cam?
It is not supposed to be centered. That's what makes it spin in the bore (or is supposed to anyway).
