2F engine swap questions
E. Washington/N. Idaho
Ok, the rules.
1. I am upgrading from a 1F to a 2F and trying to keep the 3spd AND transfer case as is. The reason is I am adding a factory PTO.
2. No, I do not want to put in a SBC. Been there, done that. Not going back there.
3. Ok, the inventory In the truck I have the stock 1F and all original drive train. I have a 2F engine with less than 65k miles on it.
4. I DO NOT HAVE:
Bellhousing on the 2F
Fly wheel on the 2F
Clutch on the 2F
So, here are some questions and I hope you guys help with more questions I should ask as well. I only ask that you stay n topic and don't try t hijack the thread into another direction. I am swapping, just need some help on the logistics.
If you don't know the answer, please don't guess!
>>> Will the 1F bell housing work with the 2F engine?
>>> What clutch do I use? 1F or 2F???
>>> Are the motor mounts in the same place? I assume yes?
>>> So, what did I miss?
Thanks guys!
Front motor mounts are in the same place, but, IIRC, the 2F uses larger bolts.
You'll need a different engine sticker.
What? That's a fact, ain't it? :p
First off it's not the 1F verses 2F bellhousing. It's three speed verses four speed. You three speed bellhousing will bolt up to a 2F. You need to use your F engine flywheel and all the other clutch.parts. Since the slave cylinder is bolted to the bellhousing nothing will change there. If you were switching to a four speed to make things simple you would want everything from a pre 8/80 with a split transfer case. That opens up a lot of other issues but is a improved setup. Depending on what 2F you will need to change the fan shroud. Everything thing else is pretty simple wiring unless you dealing with transferring emissions too.
