Hi,
I got my hands on my first FJ60 last June. Have been going through it since then. Standard stuff, vacuum & exhaust leaks, carb, ignition, emissions, rust etc. I adjusted the valves about 700 miles ago (per instructions in the many threads on here) but ever since I have found myself constantly thinking about the noise from the valve train.
I have found a few videos of running engines and mine might sound like a combination of these two but without the "valve clack" noise in the second one.
Sounds close to this?: 1984 FJ60 Questions Prior to Purchase
Not like this: 1987 fj60 toyota landcruiser, idling with a tick or knock.
What I hear from mine is more like (or at least I think) push rod noise...?
Cold (fairly accurate but a bit louder in person):
Hot (more accurate than cold video, sounds about right):
I am base-lining this off of the video in this thread of what looks like a bitchin' engine (2nd video down):
Normal Sound?
Thoughts? Does my engine sound like it is within the normal bounds? Too much noise? I've heard too much rod knock before and that was definitely bad news..
I was told that the 2F, when properly adjusted, should sound like a loud but well oiled sewing machine.. Is this correct?
Cheers
/Brian
Normal Sound?
Cheers
/Brian
