Good Day. I have done a lot of searching on 60s and found some great info here. I am looking at a 1984 FJ60 4 speed manual for $2,000 and want to get some direct input on the issues I've seen before laying out cash (no matter how little).
Motor runs nicely, tranny shifts smoothly and 4wd seems to work well. Odometer/speedometer stopped working at about 172k and the PO estimates it has about 200k on it. She says the radiator is new and head gasket replaced. Here are the known mechanical issues:
Clutch? whine: When the clutch is engaged there is a whining sound that accelerates faster than the motor is revving changes pitch with speed. There is a slight grinding sound when using engine braking. The noise stops all together when the clutch is pushed in.
Coolant Leak: It has a constant drip though the fluid was full when I looked at it. Hard to pinpoint the location as it drips down the drivers side of the crankshaft pulley and gets slung everywhere. The oil is clean and not milky and the vehicle did not overheat at all while I ran it (about 45 minutes parked and driving). Searching the forum indicates it may be a bad water pump or thermostat seal.
There is only 1 spot of rust though the clear coat is mostly gone. It's a $2k truck so not that big a deal. Frame is great, tires are new and the thing rides like a freaking dream. So much better than my 89 4Runner.
So what say you? Any input is appreciated. Also, here is a video of the engine running off a cold start.
Thanks!
Thanks!
