2F engine budget rebuild
Blenheim, New Zealand
I have a 2F that's done over 250,000km (the odometer reads 235,000, but wasn't working when I got the truck 2 years ago), and I'm pretty sure the rings are gone, & probably the valve guides as well. She burns about 2 litres of oil to a tank of gas, puffs pretty blue when working hard, & leaves a very thick smokescreen out the back on downhill runs under engine braking. And is getting worse...
Anyway - I've been given a head & block (separately). I've got the head in for a rebuild, since it had a couple of burnt valves, & the valve seats were well worn, but I think the block is in pretty good condition. The oil seals look almost new, there is no sign of scoring in the bores, no noticeable lip at the top, & everything turns smoothly. My old block serial number is 683380, and the donor block is in the 800000's (It's not handy for me to check).
My questions:
Should I pay a bit more for the head rebuild & have hardened valve seats fitted? I'm running a dual fuel setup with petrol & LPG (propane).
Could I get away with swapping the blocks, put the rebuilt head on using the old head gasket, & check it out for oil-burning & compression. Then if it needs it, I can lift the head & do the rings with the engine in place. Or am I being too cheap? I just want to avoid putting a new head gasket in - then throwing it away...
I'll definitely do the clutch while the engine is out.
Should I also pull the tranny? It's popping out of first gear under engine braking. Is there any obvious & simple fix while the tranny is easy to get out?
Any other suggestions?
Thanx
What year is the engine? Head might already have hardened seats.
Don't reuse a headgasket.
If you don't know the history of the engine I would take it down and check the rods and mains, measure the bore for taper. If its all within specs new bearings, seals, rings, oil pump, and hone the cyls.
yes get the hardened seats put in.
you should also shave the head to raise the compression - take as much off as you can - the reconditioiner will advise on that :)
Strip the block and measure everything - that will give you a good idea what condition it really is in and costs very little other than some time
Thanx
The chances that any random short block will be better than one that is burning 2 liters of oil per tank of petrol is pretty decent, but you are taking a risk that something is wrong with the block (unless you know more about it than you have told us). Compared to the labor of swapping everything, a new head gasket is cheap. Why not check the pistons and cylinders and just put new rings and bearings in the new block and check the cam and lifters for wear so that you know what condition it is in before you go to all the trouble?
My experience is that cheap "rebuilds" are false economy because you usually end up doing it over again soon. It would be better and cheaper to just swap in a good used engine that you have had the opportunity to run and test.
and while the head's in - get them to put the plug in - read this https://forum.ih8mud.com/showthread.php?t=106313
Not to hijack, but what size drill to drill it out and what size metric tap? I just noticed my "new" 2F is leaking right there:frown:
I've heard it can be done with the motor in place, but mucho easier with the head on the bench.
Thanks for all the replies. I guess I'll strip & measure everything & take my time. There really is no rush - the only cost of time is another couple of oil packs....
For the LPG tank query - most common tank location is under the rear behind the axle. Not ideal since it's the lowest part of the body, but with a good sheet of steel plate around it - it seems to slide off anything that doesn't snag the axle. For a more serious truck without a hard-top, I think a tray mounted tank would be better. Mine's about a 55 litre tank.
where do you guys put the LPG tank in a 40 . i am wanting to switch to running LPG only . but was concerned about where to put the tank .and how many liters do you carry ?
going dedicated I wouldn't want to run less than 70 litres - 80 would be better.
I oroginally had the tank under the rear behind the axle, but after an unpleasant incident with a sharp rock I moved it into the rear of the tray.
Now I have no rear seats (or rear for that matter) and it sits behind the cab.
Ed, I don't see a leak? couldn't you use standard size, no need to be metric?
I should not have used the flash. Begins right at the plug and pools toward the firewall on the head:frown:
The only reason I asked metric is I have a full set of SnapOn metric taps and dies. I think I'll see what is available set screw/ plug-wise locally and go from there. The cast stuff threads pretty easily, IIRC.
Ed
Ed
I get it now. you need to use the tools, so you can justify the expence to the wife! :D:D
OK - On to the next stage...
Stripped the block - about 2 thou wear at the top of the bore - not measurable at the bottom, piston rings showed signs of some carbon getting past the top rings, but everything looks to be in pretty good condition. Honed the bore & will be rebuilding it all this weekend - new rings & big end bearings. The head has been rebuilt - valve grind - new seats, & 30 thou shave.
Any tips & tricks regarding engine removal & replacement?
Also any ideas of simple things to look at regarding popping out of first gear under engine braking? Or just stick with the bungee cord solution to hold it in gear?
Do a search on the
Poping out of gear issue. I remember reading about is sometime ago.
JB
I've found a good used transmission, but it's attached to the older transfer case with the park brake drum on it, but mine had the the park brake on the rear wheels. Will the transmission bolt up to my tranfer case? Or do I need to keep looking? Thanx for all the help..
Ed
You want an NPT tap and plug. I can't remember if its 1/8 or 1/4 NPT, prolly says in the link posted by Andrew Farmer.
All finished. New rings, big end bearings, oil seals, clutch plate, & release bearing. My biggest project to date, but none of it was particularly difficult, & the guys at the local garage were very generous in lending the tools I didn't have (hone, micrometer, piston ring compressor), & not as expensive as I expected (under $500). And no bits left over!!! It was reluctant to start, but once I found the HT lead from the coil hanging loose & shoved it back in - she started straight off. Timing adjusted, valves adjusted & now she purrs!
More questions though:
How soon do I do an oil & filter change?
Does a "monotorque" head gasket mean there's no need to re-torque the head bolts? Or should I do it anyway? If so, how soon, & do I do it hot or cold?
Will the valves need adjusting again soon as they bed in?
Should I re-torque the manifold bolts after it's been run for a while, & again, if so, hot or cold? I don't really want to do this, cos they're a bitch to get at....
