More questions though:
How soon do I do an oil & filter change?
Does a "monotorque" head gasket mean there's no need to re-torque the head bolts? Or should I do it anyway? If so, how soon, & do I do it hot or cold?
Will the valves need adjusting again soon as they bed in?
Should I re-torque the manifold bolts after it's been run for a while, & again, if so, hot or cold? I don't really want to do this, cos they're a bitch to get at....
You should do it after the first run in, especially if you did a complete rebuild. Lots of lint and little bits to get washed out. I would at least do an oil and filter change in the first couple hundred kms.
Adjust the valves and do a head retorque at 1000km, wouldn't hurt to do it earlier though too.
Edit: Valves should prolly be adjusted after your first good drive on the highway, not after warming up in the driveway.
Retorque the manifold, side cover and pan gaskets frequently especially the first bit after install. I don't think hot or cold matters. Don't over torque the cork gaskets.
