- Thread starter
- #301
@OSS Could these issues be timing related?
The bolt holding the distributor down needs to be tightened pretty well to keep the distributor form rotating. It's hard to do without a distributor wrench, like this:What could cause you to loose timing?
Distributor not clamped down enough? Can the distributor be turned by hand with clamp tightened?
Have you checked, lubed the centrifugal advance bits?
Gonna guess that material was from the fuel hoses. I’m glad it worked. Check out your fuel filter too. And maybe start working on replacing the soft fuel lines. Just buy a roll of 25’ and do a section at a time.I opened the ports up under the site glass on the carb today. Sprayed half a bottle of cleaner in the fuel bowl. Some small small black flakes came out and what looks like a piece of silicone. It was larger and soft when I squeezed it. I dropped it when reaching for my phone.
After doing this my surging and hesitating went away. (For now, hopefully for good)
Very excited. Drove it to fill up, and around town just a little.
I don’t know how a brand new carb gets trash in it, but hopefully it’s all out.
I’m not the one to ask specifics. I just know I bought a roll at one time of 25’. But you could look up in the fsm or just take a few pieces to a auto parts place and have them match it to stuff on the shelves.Fuel filter is new.
What kind of fuel line? Anything specific?
If you are doing new hose be sure to get something that’s rated for ethanol. There is a clear reinforced fuel hose available that can be nice to use as you can see through it enough to tell if it’s flowing and is clean. It’s good for low pressure applications and just have to confirm it’s rated for ethanol in todays fuels.
You might find this article useful.
https://www.hemmings.com/blog/2014/12/05/tech-101-fuel-line-hose-what-you-should-and-should-not-use/
Stuff like this but need to check if it’s good for use with ethanol
Clear Fuel Hose - Kartek Off-Road
Clear Fuel Hose for a sandrail, rock Crawler, KOH, Ultra4, truck, UTV, side-by-side, dune buggy, mini buggy, manx, king of the hammers, 4x4 or Jeepwww.kartek.com
Wow who would have known some much info on fuel hose was needed.![]()
