2F Alternator location
Massachusetts
I was just told that my alternator is on the “wrong” side (passenger side) for a 2F engine. Should I try to locate back to the drivers side? It works as is but does seem to be a bit misaligned and will likely cause premature belt wear. It’s also touching the top of the battery which I could probably adjust with a shorter belt. I know the wiring is a mess too…that’s another project. :)
Not sure what if any year 2f would have it on the drivers side...the smog pump was low on the drivers side.
I'd start with the shorter belt - maybe low tension is what's eating your belts. Pretty easy swap too.
There really isn't much forward/back alignment on the alternator, may just be the pulley. Looks like you have a double-pulley on it and belt on the front groove...hows the alignment on the rear slot? That's more where it lands for my single setup (only photo I had handy).
79’ on mine is on the passenger side. I bought a spare one that wasn’t Toyota and had to mount it on the drivers side. I’ve since put my original one back in. Mine was better aligned on the passenger side.
Pic is the spare acdelco 334-1599 mounted on the wrong side of town.
