27 Or 30 Spline Count
Been thinking about longfields for my front axle, but can't seem to figure out what is my spline count. My fj 40 is a 69, but swapped the front end for a 76+(?) axle for the disc brakes. Spline count anyone? Thanks in advance.
I think the inners are 27 spline and the end of the Birfield is 30 spline?
Never counted them though:beer:
Ed
Inner is 30 spline, outer stock is 27 spline. You can upgrade to the 30 spline outer as well. This meens the splines on both ends of the inner shaft would be 30 splines. It does take the special birf as well so you will need to by the set from Bobby.
What Matzell said. If you want 30 spline, gotta buy the set. If you want 27 spline you can just buy the birfields or the complete set. Your inner axles will work with the 27 spline longs only.
Jeremy
The 27spline chromo-set (axles and birfs) will continue to be compatible w/MT stuff if you should ever break a birf...like that's ever going to happen :D
