Hey all — long post but I want to give enough context for someone to actually help.
I am 24yo, this is my first rig and first forum post.
I have a 2003 Land Cruiser 100 Series, 2UZ-FE, currently sitting at about 217k miles. I'm based in central CT and planning a cross-country drive to Utah this winter for ski season — roughly 15-20k miles of driving over the season. I love this truck and would love nothing more than to take it. But I've had a recurring misfire situation over the past several months that I've been chasing, and causing a ton of frustration as a daily driver and before I commit to the trip I want someone who knows the 100-Series well to put eyes on it, give it a thorough going-over, and tell me honestly whether they'd feel comfortable taking it cross-country — or whether I might wanna move on given the circumstances
I will not be offended if the answer is "sell it." However, if I’m in this forum I doubt that is ever the advice!!
Recent Major Work (for context):
- Timing belt + water pump: Nov 2024 (~196k)
- Valve cover gaskets + all 10 spark plug tube seals: Apr 2026 (~215k) — Toyota dealer
- All 8 ignition coils replaced with OEM Toyota: Apr 2026 (~215k) — Toyota dealer
- IGT2 wire to ECU soldered/replaced: May 2026 (~215k) — Toyota dealer
- Fuel filter: Jul 2026 (~216k)
- New battery (upgraded group size): Jul 2026
- New tires (Michelin Defender LTX 275/60R18): Jun 2025 (~204k)
- Front brakes + rotors: Nov 2024
Roughly $12k into the truck over the past 18 months.
The Misfire Issue — Full Timeline:
This is the part I need help with. Starting Feb 2026, I developed a recurring rough intermittent misfire pattern that has been difficult to pin down.
Here's the sequence:
- Feb/Mar 2026: P0354 (Coil D circuit). Local shop replaced ignition coil #4 with aftermarket Coil, cleaned throttle body. Resolved briefly then returned within a week asP0300/P0301/P0302/P0303/P0304/P0307/P0308 — widespread misfires. MAF reinstalled (no charge). Ran fine one day, failed the next morning with weak crank, surging RPMs, engine cutting out, transmission lurching. New codes P0352, P0353. MAF replaced again with different brand.
- Apr 2026: Brought to Toyota dealer. Tech found: aftermarket coils on multiple cylinders, cylinder 2 coil severely burnt, oil residue in spark plug tubes from leaking tube seals. Wiring from ECU to coils tested normal at time of inspection. Replaced all 8 coils with OEM Toyota, both valve cog tube seals. ~$2,750. Drivability improved noticeably — stronger idle, better starts.
- Late Apr 2026: P0352 returned about a week later (Coil B primary circuit open). Came on during a cold start, turned off on its own, returned a few days later.
- May 2026: Back to Toyota dealer. Tech found P0352 stored but not active. Measured resill testing normal at the time. Identified intermittent open circuit on IGT2 wire betweenECU connector E5 pin 8 and I2 pin 3. Soldered in a new IGT2 wire. No codes after repair. ~$438.
- Jul 2026: P0300, P0301, P0306 (cylinders 1 and 6 misfiring) + P0446. Local shop changesed to try Seafoam before swapping more parts. Since the fuel filter change (~6 weeksago), no misfire codes have returned. Running well currently. Only active code is P0446, which I've been clearing.
My read on the pattern: The local shop kept replacing parts (MAF twice, one aftermarket coil) without resolving it. Toyota dealer found the real issues — oil-contaminated coil area and a failing IGT2 wire.
The fact that misfires on cylinders 1 and 6 showed up after the IGT2 repair is suspiciou those two cylinders on the 2UZ-FE. Whether the July misfires were fuel-related (fixed byfilter) or early IGT1 degradation, I'm not sure. The harness is 20+ years old and has been physically disturbed multiple times during all the intake/MAF work.
Current open items:
- P0446 (EVAP vent control) — present on and off for ~2 years, never properly fixed
- Spark plugs — Toyota notes from May confirm aftermarket plugs were still in the engine at that visit. No record of OEM replacements since. This may still be open.
- IGT1/3/4 wire condition — unknown. IGT2 was repaired. The rest were "testing normal" i that's already shown one failure.
What I'm Looking For:
1. Thorough pre-trip inspection — brakes, fluids, cooling system, steering, driveline (front/rear diff, transfer case, CV boots), belts, hoses, anything you'd want sorted before 15-20k miles including
mountain driving at altitude in winter conditions.
2. Fresh eyes on the misfire history — I want someone who knows the 2UZ-FE well to look at this pattern and tell me whether the truck is actually fixed or whether I'm one cold morning away from another
no-start. Specifically whether the remaining IGT wires should be inspected/replaced proaanything pointing to injectors, fuel delivery, or ECU that hasn't been properly ruled out.
3. Honest "fix or sell" opinion — I've put ~$12k in over 18 months. The truck has about $15-17k in market value if running clean. I'm not going to be offended by a straight answer. If a knowledgeable person
looks at this and says "the wiring harness is going to keep giving you grief and this isolo winter XC trip," I want to hear that.
Location: Central CT. Will travel within reason — someone recommended Toyota Performance Center in New Milford and I'm not opposed to making that drive if they're worth it.
Any shop recommendations or specialists in the CT area (or western MA/RI) who know the 100 Series well would be hugely appreciated. Happy to share the full service records. Thanks in advance.
Current open items:
