24v Bulb part Numbers
Didn’t see any mention of the cabin dome light bulb. Has anyone found a 24V part number for that one or is everyone just rolling around in the dark like me lol?
Another old thread bump for me, but thank you for this information and I wanted to add a bit more
LMP 1662:
1. I could only buy 10 at a time but they were 1.42 each no biggie
2. The lamp is keyed to install only one way into the socket which is reversed from what the toyota socket wants. The tail light is supposed to be dimmer than the break light. With the LMP 1662 you will get the reverse effect (a brighter tail light and a dimmer break light).
3. There are a number of solutions to this that i thought of which include; A) dont use them B) Reverse the wire harness to match C) skid off one of the nubs on the bulb so you can slide it in the socket backwards from what was intended to match what is needed.
I went with #3. Just to note, sand down the LOWER nub, so the higher nub spring loads into where the lower nub would be. It takes a little finessing and its a tight fit. make sure to wear gloves for safety just in case.
Also, one more thing. the LMP 1662 are ~26W /~9w as opposed to the toyota bulbs which are the 5W as suggested by toyota themselves.
I cant edit my post, but considering the shipping cost from partsouq i just sucked it up and ordered a bunch of OEM 5w so i have some for the future. these bulbs should be much brighter. anything to prevent getting rear ended!
