- Joined
- May 27, 2006
- Threads
- 72
- Messages
- 187
Okay i have some issues, with my 22re, the timing is way out a whack and it will not pass smog.
The car runs great at 15-18 degrees advanced timing, but then it wont pass smog because it is not set where it is supposed to be.
i take the timing back to where it is supposed to be 6* i believe, and then it does not have enough horsepower to move the dyno.
I changed the timing chain a while back, did i miss a tooth or did i put the distributor in wrong?
the smog guy said maybe it is the TPS because when he pulled a yellow plug that goes to my fender the timing mark did not change?
I am at a loss????
Help if you can or have any experience, working with the mechanically handicapped>
Thanks
I am at a loss????
Thanks
