- Joined
- May 24, 2015
- Threads
- 32
- Messages
- 359
I know hot "spec" for the 22re oil pressure is stupidly low...something like 3 or 5lbs at idle.
My truck when cold idles at the 2nd of 4 lines on the gauge(the gauge also doesnt go above this 2nd line, ever). As the motor gets hot, the needle drops to where it rests when the engine is off. When I rev the motor hot, the needle instantly comes up to the highest reading it will produce.
I took the oil press. Sender out and screwed in a mechanical gauge. The motor was hot and reading "zero" psi on the gauge whem I started the sender removal(a.k.a just below line 1, or where it sits when the engine is off) and by the time I had got sender out, the mech. Gauge screwed in and fired back up, the mech gauge read 17lbs at idle, and the gauge was midway between line 1 and 2.(aka i was slow and the motor cooled down a smidge lol)
I let the motor idle until the gauge read its hot position. At this point, the mech gauge read 9lbs. So, when the dash gauge reads zero/no psi the engine was actually producing 9lbs. As I revved the motor, the gauge went to its highest reading at the 2nd line by about 1500rpm and was producing roughly 20lbs of oil pressure. The highest oil psi I got was 70 or so lbs at 3000 rpm or less. Didnt ever make more than 70lbs.
Basically what this tells me is my engine produces good oil pressure, despite the gauge on the dash.
Why does my dash read zero when its producing 9lbs and stops climbing after the engine is in the 20+lb range? Is the sender no good or is this just the way these gauges read? How am I ever to know when I actually have zero oil pressure? Or when its not producing a reasonable pressure at cruising 3k rpm? When it starts clattering and puts an inspction hole in the block? Permanently mount a mech gauge in the truck?
Is 9lbs hot idle good? I know its above spec, but... is it good? Aka, is the bottom end in good condition or starting to get loose?
I do like the fact that at 3000rpm crusing speed I have 70lbs of hot pressure. Or maybe not. When does the oil filter bypass? Guessing at 70lbs cause it doesnt continue to build pressure? So for a lot of the time the oil is just by passing the filter in regular operation?
The oil is conventional 5w30 btw.
