I pulled the intake off yesterday. The runners were very clean, and almost looked washed. No gunk build-up as one expects. I noticed after removing the plenum that there were pools of fuel in the bottom of the No1 and No3 runners.
The manifold was removed down to the cylinder head. Manifold-to-cylinder head gasket replaced. Replaced the little elbow coolant hose under the manifold that would be a PITA otherwise. Also replaced the two coolant hoses to the throttle body, one of which can be a PITA with the manifolds in place. Cleaned things up a bit. It looked like the injector on No3 was leaking externally as well.
I took the injectors to a local shop for inspection and cleaning. I also have a second set of rebuilt injectors on the way in case these are no good. I bought all new o-rings, insulators and seals from Toyota (in addition to the coolant hoses). The insulators on the bottom of the injectors were not in good shape (not OEM), but the o-rings and seals looked good. Don't matter, all will be replaced. I'll pick up the injectors on Monday ($20/ea in case folks want to know).
Just for ducks I also replaced the semi-circle plugs at either end of the cylinder head, and the gasket to the rocker arm cover. I have 120K on this engine so I guess it's about time.
Gotta get my baby running right.
