Ok short run down 86 4runner 22re. sat 6 years aprox. replaced fuel filter. plugs wire cap rotor,. did all this because number 2 and 3 wernt doing there job its running on number 1 and 4. i can unhook 2 and 3 plug wires motor dont change a beat. Pulled plugs out there soaked in gas. checked plug wires for spark got shocked. spark confirmed.
heres a link to vid of motor running and two plug wires unhooked. I found one of the injector splices in the harness conection was nice clean and copper no corosion so i figure the other splice should look the same. couldnt find the second one. but i havent took the upper intake off yet,. Would throtle position sensor cause my issues .
:whoops:
VID00022-20120616-1406.mp4 video by largemouthfeaver - Photobucket
checked compression all pistons got 75 on first full revolution and 150 on the third rev of motor on compression teser. they were maybe 2 to 4 psi off each other . It has 10 fresh gallons of gas. seafoam in the tank. Need ideas sugestions
:whoops:VID00022-20120616-1406.mp4 video by largemouthfeaver - Photobucket
