212HP. Really??? It doesn't feel like it!
My 1997 is sloooooooooow. The engine is rated at 212hp but it feels more like 112hp :bang: The engine is running within spec and a recent compression test produced perfect numbers. It doesn't use any oil.
Is there a simple sub-$1000 method to get a ~10% power increase from this engine? Perhaps at 200k the cat converter is clogged? Is there a "chip" for the engine computer?
You could check your cats, no one here can tell if your cats are clogged.
If you want HP, read up on superchargers and add a few grand to your budget.
Time to sell it and buy a 100 series. Seriously, there is no low budget power booster for these things. Best bang for your buck is to make sure the engine is in top condition with a good tuneup, ie. plugs/wires/rotor/cap/filters/pcv, but you won't see much difference in power.
For all the complaints about 80s being slow, I think they have adequate power. The key word being adequate. But I don't find it slow in anyway. I agree on checking the cats.
Although my V8 Explorer and 1 ton Suburban are faster, I think my 80 is faster than my 97 Pathfinder was. It also doesn't sound as strained going up passes.
Put 5.29s in it. :)
Mine had 165k on it with impeccable maintenance when purchased, but seemed lifeless. Having since replaced almost all parts except anything engine internal there is a power difference. The following in consecutive is where i noticed the most improvement:
oem muffler replacement by bosal
fuel filter
bg44k fuel cleaner
high flow cats
o2 sensors
What i replaced with no noticed improvement, although im sure they had been replaced by receipts so if you have no history theyre cheap to do.
plugs
cap.rotor
Or swap a v8
No.
Drive a 1991 FJ80. After that you will think that you got more than a 10% increase in power for free.
That's funny
I did a fuel system flush and noticed a bit more pep. Ditto with yanking the OEM exhaust.
I agree with most here. After all, it is a truck. Not that slow though. I had a stock 1997 and did 18 flat in the 1/4 mile, that's faster than some sedans. After installing a better flowing muffler, 17.80's. For a 5000 pound truck with full time 4wd automatic transmission and being a Lexus which is slightly heavier than the Land Cruiser, not slow at all.
It could be there's something wrong with your engine to make it sluggish.
My rig weighes approximately 6600lbs and I'm running 33s with stock gears and a bone stock 1fZ and it feels fairly adequate to me. No sports car, but I can still pass people and feel relatively safe about it. I can climb steep grades and still keep up with traffic and do the speed limit or more.
Then again, the rig my LC replaced was a 1989 Toyota SAS pick-up built and loaded to the gills at over 5300lbs with a 22RE making barely more than 100 h.p.
That rig required patients while driving.
Funny thing is...I can't really recall losing a significant amount of power between stock and now despite all the weight, lift, mods and bigger tires.
That all said, I do still lust for a supercharger......
Thanks for the replies.
For the record I don't expect this vehicle to be fast but a little more power would be nice. I am confident that the engine is in good working order.
The two most likely arears for improvement are the O2 sensors and the cat converter.
Has anyone installed a hi-flow cat on a 1997 Land Cruiser?
