kcustom73
Stretched it...
The other day I took the 40 on a little highway trip and when I came back parked it back in the garage as I usually do. Later in the evening I went into the garage to take a look at something and I walked in to the smell of gear oil. Took a peek under the 40 to find a 12' puddle of gear oil under the transfer cases.
For the last week or so, I've left it parked in the shop and I've noticed that it keeps dripping. Now I've checked all the levels and I pretty sure the oil is coming from the doubler and dripping between the double and splitcase (see below for leak area)
Now I did check the level in the splitcase and found it to be overfilled a bit so I'm thinking the cases could be a little over-pressurized (I've got both cases and diff vented to a filter under the hood).
Now I've ordered a gasket set for the splitcase and will be pulling it off the back of the doubler to figure out where the leak is coming from. I've done some searching on MUD for some info and the only real info I found was on Chicago's build (almost same setup - my setup is GM 6.5 turbo diesel, 4L80e, 203 doubler, splitcase).
Now I'm trying to figure out what caused the leak. It could be something like Chicago's build and something is loose. Can the vibration of the diesel plus the length of the doubler/splitcase combo be just to much for the one cross member at the transmission? Maybe I should add a second cross member at the back of the splitcase to support all the weight...
What do you guys think? (here are few more pics of the setup).
