203 doubler - 88 splicase leak
what keeps the oil from travelling down the splines and out of the transfer case on a stock unit? I wonder if there's some kind of shield that removes most of the oil or creates a low pressure behind the oil... on 4 speed Super t10s, there's a speedometer gear that prevents large amounts of oil from travelling down the shaft - the rest is kept inside by a seal.... I've no idea on the dual case - but since you didn't have extra parts, I'm wondering if you're missing a part.
sorry I can't be more help.
Is the vent on the Split tcase plugged at all?
Mace, vent looks good. It is tied in to the same line as both diffs and 203 going up to a small filter under the hood. I wondering if I should just revert to the old style vents (if I can still get new ones)
Reason I ask is that pressure usually drives a leak from the tcase. Even more so if the oil does not return. Is it clogged in the Tcase?
You could easily just add a tube between the fill on the 203 and the Tcase. That would keep them level for now.
