I bought a used one, so I could install a "pretty" one when I do mine and avoid down time.
What year truck? There are differences early to late as well as replacement axles.I just wrapped up my Birfield job this weekend. I had forgotten what an incredibly dirty this job is.
One the driver side I had room to spare when installing the snap ring on the outer axle end. On the passenger side it was a tight fit. I inserted a nut in the axle end and gave it a good tug with pliers to ensure the axle was pulled out as far as possible. I am pretty confident I fully seated the bearing races and seal in the hub. New Timken bearings and races. I torqued the hub adjusting nut to 43 ft-lbs per FSM to get everything cinched together and ultimately at 20 ft-lbs to set the preload. After a highway test drive both hubs measured the same temp on the IR thermometer and everything spins smoothly. It still bothers me that one side had a tight fit on that snap ring. Is this cause for concern?
Don’t know.....I’m on step 11come out ok? Probably a good reminder to get Palladium that matches the furniture.
Wait what? Rear tubes? I thought they were only in front? Holy crap? Really? How’d I miss that? But yeah, that seal at the rear between roof and “glass” when closed leaves about a 1/16 gap.Well the seal on the sunroof should not really make a perfect seal to keep things dry. the rear tubes didn't get pushed off when you were trying to snake them lasttime to clean them? If you look at some pictures posted by @ZeGerman he had to reinforce the tubes in order to keep them from pinching so they could flow, but i think you would only see that by dropping the headliner.
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
Recent thread on that with sound deadening on the roof.I forget about insulation, good call!!! Will look into that!
Nice job on getting it evenly blended and spread around so it's less noticeable!This was ground zero with a dime size glob here. Knock on wood, looking good.
