Amazon product ASIN B07L9Q43T2
Has fm reception too... Faster install ha
at home....oddly, she seems fine with that. “Wait, so I can’t go and you’re taking the boys for the weekend?! Ok!” Really not sure that is the answer to your issue, but something in the back of my head says somewhere not to use that particular wire.
thread....coming soon to a mud near you!!!Follow the directions.
Lube your shafts, check your nuts.
Doesn't specifically matter.Hey BILT, when checking dese nuts (71 lb-ft), does it matter whether I do it with load on axles or axles off ground? TIA!
So what exactly is the check your nuts procedure? (All: Pls spare us any salacious commentary thanksDoesn't specifically matter.
The load is on the bearing inside the knuckle.
The pin of the shaft holds the bearing in center but doesn't carry load.
The steering arm is what is critical to get tight. Use a deadblow hammer to hit the radiused part of the arm while torquing.
Just place a torque wrench on them and tighten in a cross pattern to 71 lb-ft. If tightening after a rebuild, you do it in about 3 stages (15, 50, 71). If just checking, do a cross pattern at 71.So what exactly is the check your nuts procedure? (All: Pls spare us any salacious commentary thanks)
