Stock up on brake fluid you are going to need it. I go with the gatorade bottle bleed method and it works well.
ha. The LSPV is on its second or third Quart and still blowing bubbles so I got kicked out of the house I’m eating dinner in the garage in the grubbiesStock up on brake fluid you are going to need it. I go with the gatorade bottle bleed method and it works well.
I'm doing the bottle method, clear line is above the bleeder. I wrapped the bleeders with T tape to prevent suck in. How do I active the ABS? I get a very stiff peddle with key off, the to the floor with engine on.How are you bleeding? Pressure from the res, pumping by the peddle or sucking from each point? If you are sucking you can pull air through the bleeder and it seems like the air is from the line. If you are pumping then long clear tube up high will let you get most of the air out. You need help or a board to hold the peddle down before you tighten the bleeder. If you are pushing from the res then you can push air out all 5 bleeders but the abs will still keep it soft until you actuate it on each side. Sometimes a couple of times.
This way? Might be more than I have in me tonightI just took a look at the FSM page BR-58. You can activate the 3 solenoid valves and run the pump motor on the ABS actuator by disconnecting the two plugs at the actuator. Then you connect pins 1, 3 and 4 on the 6 position plug (wire colors light blue, light blue with green stripe, light blue with red stripe) of the actuator side to ground. Connect pin 1 of the 4 position plug (white with black stripe) to ground. Then connect pins 3 and 4 of the 4 position plug (black, red stripe, black, blue stripe) to battery voltage. The FSM implies that you don't want to run it this way for more than 15 sec.
My preferred method.Take a drive along a road with a gravel shoulder, put a couple of wheels on the gravel and hit the brakes fairly hard. Might have to do this a couple of times with bleeding in between
I like this plan....I just need to find a dirt patch without getting on the highway!Take a drive along a road with a gravel shoulder, put a couple of wheels on the gravel and hit the brakes fairly hard. Might have to do this a couple of times with bleeding in between
. Not feeling too smart!will send later....just found out after messing around for 30 mins. Safety restore sent me someone else's Rear passenger Seat belt, versus MY PASSENGER FRONT! Aggghhhhh....will post that on the mainNot sure what harness adapter you ended up with but the metra unit I have was pretty easy. I had to wire it in but it wasn't difficult.
Any photos?
So should I try snipping the antenna wire on their harness? I don’t think any fuses blew, but will double check. If it gets me on the road.I seem recall popping fuses if you use the antenna wire on the harness from them or deck. It's been over 10yrs though, so memory is fuzzy.
I ordered all those harness bits, but not going to arrive before my trip on Friday. Oh well.in the future i recommend you wire them yourself as it is very easy 15 min job and is mostly, just match color for color on the wires. It also makes the rest easier to understand and you have the option to not connect somethings....
You could or just "de-pin" it, It would be whichever is labeled ANT or something close to that.So should I try snipping the antenna wire on their harness? I don’t think any fuses blew, but will double check. If it gets me on the road.
Thanks all.
Really not sure that is the answer to your issue, but something in the back of my head says somewhere not to use that particular wire.You could or just "de-pin" it, It would be whichever is labeled ANT or something close to that.
