- Thread starter
- #21
Trouble???
should I do anything to polish that surface up
That’s a wrap for 2 day. About 2.5 hours all in. Got the axle and birf apart and soaking. Yeah. Now, just freaking about those gouges.
I hear you @KC masterpiece I adhere to “leave no trace” when all is said and done.
!"You got it this far...
Jack it up under the front frame horns, droop that axle end, drop in new springs and shocks, extended brake lines, swaybar drops and some new radius arms and... POOF!
"Jeez Baby, I don't know what happened.I rebuilt the knuckle and somehow the truck got lifted. "
"It was!"
Oh, that trick with 2 studs to help reassembly is very much worth it!
On the Russell bleeders, compare them to one of the old ones you pull out. The tips on the factory nipples are blunted. I ground mine down to match the factory tip, otherwise you may end up with leaks.
