Found the answer: Lexus Captures Second Baja 1000 Race Title | Toyota Parts Center - https://parts.olathetoyota.com/blog/5127/lexus-baja-1000-race-victory
Hardly stock!
Baja1000 “stock” definition is very loose.
Tidbits:
We also had TRD engineers remove 65 lbs. of wiring and sensors that were not needed.
We are sponsored by King Racing Shocks, and the front runs two King Shocks per wheel. I have mounted a 3.5” coilover that passes through the upper mount (cut out) into a higher custom shock mount location that ties into the roll cage. the secondary shock is strictly a 3.5″ triple bypass. At the full droop and full bump, I get almost 15” of usable travel. This is possible with the stock arms, 4WD half shafts, and stock steering components.
We did a lot of static suspension tests with the 37” BFGoodrich KRT race project tries and even added a 2.5” body lift to get more up travel.
Q: Have you had any electrical issues with it?
A: We did when the vehicle was first built. LX went into “Limp Mode” for 3 races, which cost us the Championship last year.
One major strength of the LX 570 is the full-time 4WD system, the center diff lock, and the rear air locker.
Hardly stock!
Tidbits:
