Doesn't that just add insult to future injury? They molded in the @#%$@# stamp plate, then later figured out a decal worked fine, and eventually stopped using the stamp and decal altogether!?! But thanks for leaving us with a stress crack magnet.One thing I now notice is that it doesn't have the vendor markings.
OMG, "crack magnet".Doesn't that just add insult to future injury? They molded in the @#%$@# stamp plate, then later figured out a decal worked fine, and eventually stopped using the stamp and decal altogether!?! But thanks for leaving us with a stress crack magnet.
I just purchased a 2009 LC with 148,000 miles. Records indicate water pump replacement, but I did not see mention of the radiator. I imagine this is a pretty typical stress riser beginning to form. Any indication as to how long before failure typically happens?
I have an extended bumper to bumper warranty for the next 6k miles, so I may try to have this fixed before it pops. If denied I'll order a new one and drop it in I guess.
if you're taking any long trips I'd replace it. Nothing worse than having a failure when you're hundreds of miles from home and then losing vacation time. Around town your worst case scenario is a blowout and a tow home.
I ended up getting it replaced the day before I left for CM by the Toyota dealer. Looks like same design.....
So just brought home my new radiator. it has the "fixed" top plate which is great. 1 potential issue quite a few of the metal fins have some damage. you think i should return? Or no big deal?
I talked to the parts guy, he ordered a new one, said i could exchange tomorrow morning. They are 10 minutes from my house, might as well just replace. The local Toyota dealer here is very cruiser friendly and take care of all the guys in the local cruiser club. Probably not a real issue, just after i shelled out all that cash I'd like it to be perfect. most doesnt look like itd cause any issue, but 1 line along the edge does look like itd restrict airflow a little.As long as the tubes all looked good I’d fix that. Would take less of my time than arranging a replacement.
You can buy oring picks in sets of four different shapes.. I’ve found that the multi-angle one is particularly good for radiator fin touch-up.
