SOLD 2003 Lexus LX 470 + Recovery & Camping Gear!
Status
Not open for further replies.
Denver, Colorado
Year
2003
  1. LX470
Aurora, Colorado 80015 United States
Mileage
296678
Color
hsl(0, 0%, 30%)
Outside Link
https://denver.craigslist.org/cto/d/aurora-2003-lx-470-modded-lots-of/7913338692.html
PRICE: Asking $7,250 located in Aurora, CO
I've decided to sell this vehicle as I'm moving to Chicago and really don't have a use for a built out truck like this so far away from the mountains. I've owned this vehicle for 6 years and it can easily be driven daily right now (and it currently is) but it needs some work to be in tip top shape. I have this truck priced to sell to accommodate the repairs that may be needed and the higher mileage. I am going to be as upfront about everything I am aware that needs fixing for transparency, and I'm more than happy to provide any additional information. Don't judge a book by it's cover though, despite the work needed and mileage, this truck really does feel like a tank and drive/off-roads very well.
Overview:
- 2003 Lexus LX 470
- 1 accident (minor bumper damage, no structural or frame damage)
- Clean CO title in hand
- Passes emissions with ease
Known Issues:
- Crack along front windshield (does not leak)
- Hairline crack in passenger fender from snorkel vibrations against body panel
- Needs a Steering Position Sensor (approx $150 on eBay, located on steering column under clam shell; steering wheel is very crooked because of the bad sensor, but wouldn't be a difficult fix and it still drives fine & has a perfect alignment)
- Needs new tires; some irregular wear on driver front tire due to what I believe to be worn out lower control arm bushings
- Split tie rod boot; could use a replacement
- Mild creaking front end noise (I think it's the sway bar bushings needing some grease)
- Passenger front seat wont move backwards away from dash (in a usable spot, but I haven't been able to diagnose the issue; still tilts forward and backwards)
- Scratches from off-roading; this truck has seen many off-pavement miles and thus has many "custom pinstripes"
- Mild hail damage on hood and roof; not that bad imo and the paint color does a good job of masking the dents
- Dent on rear driver side of bumper from bumping a rock on a trail (not structural, entirely cosmetic)
- Possible PS valve cover gasket leak
- Moderate leak of an unknown source, possibly the rear main seal? (doesn't leak enough to necessitate topping off between oil changes)
Maintenance Done:
- Sway bar bushings (RockAuto - FelPro?)
- Heater tees (Toyota OEM)
- DS valve cover gasket (Toyota OEM)
- PCV valve replaced (Toyota OEM)
- Both front wheel bearings replaced (Toyota OEM)
- New radiator (Toyota OEM)
- New spark plugs (Denso aka Toyota OEM)
- New alternator (Toyota OEM)
- New coil packs (Toyota OEM)
- AHC fluid flush and re-spec (Toyota OEM fluid)
- New battery (Optima Red Top)
- DS upper control arm (Toyota OEM)
- New stereo receiver (Lexus OEM)
- New timing belt (Toyota OEM)
- New belt tensioners (Toyota OEM)
- New water pump (Aisin aka Toyota OEM)
- New fan clutch (Aisin aka Toyota OEM)
- New bearings for pulleys (NGK)
What it comes with (the GOODIES):
- ARB Deluxe Bull Bar
- Badlands 12k synthetic rope winch
- eBay replica Safari snorkel
- Coastal Offroad sliders w kick-out and top plate
- Ironman 9" Meteor driving lights (insanely bright)
- ARB fog lights
- Optima red top battery
- DBA T3 slotted rear rotors / Brembo blank front rotors / DBA brake pads
- Grom Vline 2 Bluetooth/Car Play/Android Auto head unit modification (doesn't affect original functions at all)
- JBL 6" speakers (front)
- Kicker 4.5" speakers (rear)
- Skar 10" subwoofer (OEM location; bumps pretty good!)
- Ironman 4x4 40L water container (was once hooked up with a Shurflo water pump to provide clean drinking water on the trails; everything is still there to hook up if desired)
- Custom wood rear drawer system (the right side drawer has started to sag and can be a pain to open; the left side is still perfectly functional and works great! The right side is meant to be a pull out kitchen and comes with a small pantry, storage area for utensils/plates, a CampChef 2 burner stove, and multiple fuel cans for the burners. The left side is meant to store recovery gear and tools)
- SetPower RV45S fridge/freezer (full functional, not hooked up currently)
- Hi Lift jack
- Traction Boards
- Ironman Heavy Duty Off-Road Recovery Kit (SKU: IRECKIT003; comes with 30' 17.6k lbs snatch strap, 65.5' 10k lbs winch extension, 10' 26.5k lbs tree saver strap, two 4.7 ton D shackles, winch recovery gloves, carrying bag)
- ARB tire patch kit
- Canvas tool bag
- 30' 30k lbs kinetic recovery rope
- Two 38k lbs soft shackles
- 5 gal jerry can
- Like-new OEM replacement steering rack (approx 10k miles on it; not installed)
- Front & rear dash cam that's also a replacement screen for the rear view mirror (uninstalled)
If you have read this far, I commend you. I think the level of detail I have is a testament to how much I have cared for and loved this Lexus since I bought it. If you are interested, take a look at my IH8Mud forum thread where I've chronicled everything I've done with the LX since purchase. I think it is a wealth of knowledge on what I've done to it:
If you would like to ask any questions or would like to see it in person, feel free to hit me up on my cell, message me on here, or comment on this thread. Thanks for looking!
Mike
210-846-4950
how’s the interior? Any rust?
The interior is in decent shape. The center console is worn down from years of elbows on it, and there is a small tear in the leather seat cushion of the driver’s seat. I’m at work right now, but later today I can try to get some pictures of the interior to share.
Also, no real rust. There’s a tiny bit of surface rust on one of the sliders from it being used and I hadn’t resprayed where the rocks scratched it, but I can fix that relatively easily
This has been sold
Status
