It's home... congrats!
It's here. It's finally here. What an incredible machine. It's so easy to see why land cruisers have such a cult following. I absolutely loved my 80, but this this is light years ahead as far as comfort and power are concerned. I have no dirt time yet, but I know it will take me where I want to go.
I did indeed.Did you post this on Facebook to the TLCA group? It looks mighty familiar...
They made a HUGE difference for me. They're kind of like a little projector with a single LED behind it, and they really do shine. I think an aux light that points down at the ground more would still be a good addition, but these definitely help with night time back ups.do the reverse LED that pfran sell really make that big of a difference? I bought some reverse LEDs off ebay but they don't seem any brighter than stock. just a more white/blueish light
do the reverse LED that pfran sell really make that big of a difference? I bought some reverse LEDs off ebay but they don't seem any brighter than stock. just a more white/blueish light[/QUOTE
Congrats! I'm glad you got it home safe...
As for the CB, I wouldn't mount it there. But then again, I use my console way too much for that. I have my 2m and CB mounted on either side of the trans tunnel. It is out of the way and convenient to use.
Oh, speaking of center consoles, you need one of these way more than you know: Accessory Panel Unit-100 Series early
I would say that if you are running Old Man Emu torsion bars, and they are cranked enough to fit 35" (34.6") tires, then you more than likely need a diff drop kit. I purchased mine from Slee.
On a side note, my middle row dome light seems to be a bit skeewompus. With the switch in off, no light, on position gives constant light, door position gives constant light. Any idea how I can get the lights to go off when the doors are closed?
Sounds like one of the plunger switches in the door aren't working. IIRC, the plunger pushed in completes the ground circuit and they unbolt with a 10mm bolt. If you pull the bolt, it will break the ground. I would put the light in the "door" position and pull each plunger with the other door shut. When the light goes out, you know which plunger is bad.
