Media 200 series picture thread
Photo/Video/Audio threads
Questions for all of you in these videos: What drive mode are you in? 4 LO? Center Diff Locked? Descent control on? (when descending, of course) Anything else?
Loved watching all the videos from Cruise Moab! Super inspiring to see 200's take on Wipeout Hill and Hell's Revenge (with some expert spotting!) The timing of our family's cross country move led me here to Moab the following week and today's our last day. We had a fantastic initial run at Dome Plataeu (pics in another thread) but yesterday, I realized that I had the itch to try something a little more challenging so I took the fam to Fin's N Things. Unfortunately, I couldn't get much video or pics because my passenger were my two young kids in carseats and my 74 year old mom in the driver's seat (wife was working back at the house) but super excited to have made it through (mostly) unscathed. Lots of parking on the flat bits, hopping out, and trying to self-spot. We did take a couple hits to the running boards and rear bumper but I'm looking to replace both when we arrive in VA anyway (lead times were way too long before we left). Thinking Bud Built for sliders but would love any recommendations for a rear bumper - not looking for swingouts as it's still the family car and I don't want to make it harder to access the rear.
Here are a couple of shots from when I asked the 6yo to hop out, climb up to a safe location and snap some phone pics. The cargo box on top is empty during the run so not much extra weight up there - it's just a PITA to remove.
What a memorable trip to get to take with your 74 year old mom and kids.
I'd assume everyone is in 4-Lo. Locking the center differential tends to vary driver-to-driver. Some folks default to turning it on when driving offroad while others use it selectively as they want more traction. Generally, I fall into the former category; however, in Moab, I tend to use the center (and front/rear if needed) selectively based on obstacles/terrain. Simply getting to the right offroad tire pressure (18-25 PSI for me depending on the trail in Moab) and 4-Lo was enough 99% of the time.
More specifically, though, I use 4-Lo + center locked on extreme uphill or downhill climbs (like those on Hell's Revenge). I like having the center locked going downhill in case I need to reverse.
I'm in 4-Low any time I know my speeds will be sustained under 10 - 15mph due to terrain and certainly anytime I am dealing with an obstacle. I lock my center diff basically anytime I am off-pavement. The truck is just more sure-footed, especially at higher speeds on dirt/gravel/washboards. I think of the center locker as a safety feature. If I'm in 4-Low, the center diff is already locked and will stay locked. I haven't used any descent control, but played with CRAWL on "Behind the Rocks" and its was amazing for descending over obstacles. It felt like cheating.
Is there a speed limitation with the center diff? This question is really aimed more at "super heavy rain" or "heavy snow" and obviously safe driving habits apply here too. I'm really just curious if I shouldn't have the center diff locked when I'm traveling faster than say 40.
I never think of it as a speed issue, but instead a traction issue. I would hesitate to use it at high speeds in rain, on pavement as traction can come and go. With snow, I’d be more comfortable using it at higher speeds. I generally don’t use it at all on pavement, though. If conditions were bad enough to engage on pavement, I wouldn’t be reaching those speeds anyway.
IIRC, you can switch the center diff lock on the fly to about 60 mph. That's just switching, pretty sure if it's already on, it stays engaged from my experience running on sand even past that speed.
I would caution its use in certain low traction situations. It turns VSC off, which is beneficial to most drivers in adverse conditions. Locking also forces slip of tires in turns and could cause a loss of traction in itself in something like rain or snow on road. Sand and certain deep snow situations are different in that it's beneficial to keep momentum in low traction situations, and locking with VSC off allows distribution of power more evenly to spin tires without VSC shutting down the party.
Since CDL can be switched on the fly, I generally don't engage it unless I'm traversing an obstacle, very steep uphill or downhill.
This! I spent about 2 hours recently trying to self extract myself from an open field of snow with maxtrax and didn't make any progress until I unlocked my center diff. Sometimes you need wheels speed and VSC.
Just wondering if you also tried to use crawl control?
I did, forward and reverse and just couldn't get enough wheel speed to get a bite on the maxtrax to pull it under a wheel.
Adventure and good story to tell around the camp fire in the end. I've done the same in my 4Runner back in the day, before maxtrax. Would have enjoyed being stuck out there with ya!
I'll go against the grain a little bit here and say I rarely use my CDL when wheeling except when I know I am about to go up a long, loose, steep hill, and I only activate it for the climb and turn it off right after. For trails where I know I will be doing a lot of climbs, descents, or crawling and know my max speed will rarely go above 10mph, I am in 4 low. In the 13+, the 200 automatically goes into Multi Terrain Select/MTS mode when in 4 low, and I generally have it set to the least aggressive setting which is "Mud & Sand". As I approach climbs or obstacles, I will turn the MTS dial clockwise to increase how aggressive the system responds and use the most appropriate setting for the situation, and then as soon as I'm done with the obstacle I turn the dial back to "Mud & Sand".
MTS works by pulsing the brakes very quickly to stop wheelspin and "send" power to the opposite wheel on the same axle, and "Mud & Sand" responds the least quickly/aggressively whereas "Rock" responds the fastest and most aggressively. The reason why I'm constantly adjusting the settings is to be as gentle on the vehicle as possible, and that is also why I try to use the least amount of throttle as possible. The saying goes something like "As slow as possible, as fast as necessary", and on a big heavy 200, that will go a long to preserving it mechanically - mechanical sympathy if you will. To answer your questions, there is no one magic setting for all off road situations, so it's important to try them all out and see what each feels like and when to use it. Side note - I do not use CRAWL or Turn Assist unless someone wants to see how it works and I'm not in a dangerous position.
Totally agree on the MTS usage. I was running in "Mud & Sand" mode on Wipeout Hill and forgot to switch it up to "Rock & Dirt" on that obstacle climb. Obviously the bad line is what caught me up on the rock, but I don't think I would have smoked the back tire if I had been in "Rock & Dirt". There is a much bigger difference between the MTS settings than I think most people realize, and that setting can be the difference between making it and getting stuck. I need to do more research on how CDL couples with MTS in different terrain varieties. I suspect there are more combinations of technical wizardry than could be distilled down to a usage matrix, but I might try and put something together. I'm sure it won't be controversial at all.
Anybody ever see this color in the wild? I definitely have not.
Pacific Blue Metallic. Our 200 is this color. It’s rare. Like Amazon Green. If accident free and some records, This looks like a very nice example with only 115k miles. Wonder how much they’re asking.
Too much skinny pedal?? :hillbilly:
One last Cruise Moab video featuring @TheGrrrrr @Markuson @RobW0 @Gregtoy144 on Wipeout Hill.
Awesome. I've looked into this Moab thing among others. There's plenty of off roading to be done here in the east, but it's not all wide open spaces where you pretty much won't screw up the paint.
My question is where the hell is the nearest gas station when you're so far off the beaten trail out West?
If anyone from the area wants to meet up at Windrock, LMK. I haven't bought off road tires yet so I'm not going to push it too hard but they have something for all levels there.
Awesome. I've looked into this Moab thing among others. There's plenty of off roading to be done here in the east, but it's not all wide open spaces where it's not easy to screw up the paint. This place is right outside Knoxville.
My question is where the hell is the nearest gas station when you're so far off the beaten trail?
You should ask @ga12r1
Just to jump on the discussion about Locking center diff earlier, do you guys ever use the ECT Power button? On road or off road? Maybe whole towing?
