$20 power window master switch
FOG TOWN->SF<-
Just want to give a review for those eBay master switches for the Fzj80. I was a bus hesitant because of the price compare to the used or even new ones out there going for over $100.
I bought this switch for $20 delivered and it works just as described and the fit was great. Just wanted to share a a couple of picks for those who need a master switch.
They won't last...but I do have something similar that I keep in my 'spare parts' box for emergencies.
It's not a lot of fun taking the OEM apart and cleaning all the contacts...but it has always seemed to rejuvenate mine.
I agree it won't last as long as a factory switch, the problem I've found is the contacts in these aftermarket switches. Their contacts just aren't heavy enough to withstand the repeated arcing, and amp loads, so their life cycle will be much shorter then the factory switch. That's the reason why the factory switch cost so much, it's a heavy duty unit with a proven long life.
My OEM switch finally died, and no rebuild/cleaning helped it. I went with the cheapo and it works fine so far (it's only been 3 months, though). However, due to how it's put together, it isn't possible to do the auto-up mod the same way as the factory switch. I'm not saying it's impossible, but I have no clue how to approach it as it's totally different from the factory switch. Sad, since I used the auto-up feature frequently.
I had one from Switch Doctor and it didn't last....
Driver's window would sometimes not go down when I wanted it to...
They sent me a replacement and it worked for a while, but then one day when it was all the way down, I noticed the glass would randomly inch its way up until fully closed :confused:
Turns out it would do this even after it was up, in turn overheating the circuit breaker on the motor, which caused my random issue when not going down :bang:
Ordered a used OEM unit from an EBay boneyard on the cheap and when it arrived, realized that it wasn't from a TLC or LX, but a Corolla :meh:
Looked identical in every way to my original (except for the atached bezel), so I popped it in and it's been working fine ever since :redface:
I bought the Switch Doctor version one year and one month ago. Just swapped it out today for my old one because 5 of the 8 functions stopped working recently. My old switch works except for the driver's window. Will start searching for a used unit.
Anybody have the Camry/Corolla model years that are interchangeable ?
