1st year apprentice here! diff lock the switch
Hey everyone! hopefully on Monday night I'll finally be the owner of a 97 fj 80.. Ive been searching for months on Craigslist and other local dealers for one. I'm kinda old school and probably would never buy one on eBay without physically seeing it. I live in Chicago so finding a 95 -97 that is rust free was tough. but I got one that came from San Diego
100 series land cruiser are a dime a dozen around here and although when they're decked out with aftermarket bumpers, lift kits, tires ect.. I think they look gay side by side with a 80series. I sorry, but that's the only way I can describe it.. and that awesome inline 6 seems bullet proof compared to the later 4.7 v8.
So the question I have (which I'm sure you guys probably answered over and over again) is about the diff lock switch by the steering column that mine doesn't have.. is the only difference between one with the switch and one without is just the switch itself? Ive seen that switch for sale online for about forty bucks. I swear I saw an article that said on a 97 the harness is there.. just plug and play! but now I can't find that article. is that true?
also, the interior is near mint except for the driver seat.. kinda worn out :(. does anyone have a good review on seat covers that actually fit that are reasonable priced? under $100
Thanks in advance !
MachineBob
Adding the switch for front and rear lockers does nothing. The main wiring harness is universal so it has some of the required wiring but other harnesses, locker ECU, and the front and rear 3rd members are required. Look at another $2000 if you can score the parts used. This is well documented so do some searches.
If you just get diffs (third members) you'll have to modify the non-locker ("open") axle housings extensively to install them.
Complete list:
Diff lock switch (magic dial)
Diff lock ECU (goes near passenger foot well)
Locked axles OR diffs and rear pass-side axle shaft (and means to modify housing)
Rear body cross harness under hatch
Rear diff lock harness from axle to cross harness
Front diff lock harness from axle to chassis
Other than that the existing harness is set up with all of the needed pigtails (ECU, knob, front diff) already.
I paid $1500 for everything needed and in decent shape. Try and verify that the front axle is straight.
Welcome! :flipoff2:
Yep the magic switch is sought by many, years ago it was rumoured that someone would fit the switch and then deny understanding anything about it. The result the buyer thought he had great deal as the vehicle had OE lockers, arrives home and finds there was no lockers. :mad:
regards
Dave
thanks guys... I knew it couldn't be that easy. in a way, I'm excited about installing all the parts necessary to have diff lockers. the only way to know your truck is to work on your truck!
thanks for that list bloc... would you suggest using used factory parts vs aftermarket? whats more cost effective? I'm using it as a daily driver and road trips with the kids so reliability is huge.
in the meantime, I have the urge to start tinkering with it. I read about some simple mods like add a CDL and the 7 pin mod. anyone do this ?
please advise
thanks!
This link will have all of your answers, and then some. You can search within the thread for quicker results. Most of your initial questions are likely going to be the common ones that many of us have had - searching for the answers before asking the questions keeps the forum from filling up with 900 of the same questions. Not trying to be rude. Lots of people just miss even seeing the FAQ sticky. Congrats on your pending purchase!
FAQ for 80/LX450 -Mar 2015 -Added Battery Information Thread
thanks John. I sure missed seeing the FAQ that link is exactly what I was looking for!
If you are good with a wrench and have all of the appropriate tools (and no problems) you could get the factory axles physically installed in a weekend, pretty easily. Maybe even a day if you push. The rest is stuff that won't disable the vehicle.
An alternative that some use is ARB air or Eaton/Harrop E-lockers. Problem with these for your use is the truck will be out of commission while you send your open thirds off to get the locker installed. Also with the ARB you need to install an air compressor. Cost is substantial.. most certainly not less than finding toyota e-locked axles and parts.. however your axle parts are known.
There is a recent thread debating this very topic (OEM vs Non).. As someone mentioned, lots of this is in the FAQ and discussed often.
We're hitting a point where locked (factory e-locked 80's) - unless you find some little old lady from Pasadena who only drove it to church on Christmas & Easter, are or have had a user who (over)used that 80.
ARB's are tougher, and you can still find creampuff open diff 80's.
I'm betting the next 80 I buy I'll just get a creampuff & do just a rear ARB.
I've had dual ARB's, my e-lock converted 80 - and between a center diff lock switch & rear locker, I honestly think between both 80's I've used the front one 6 times - and even then the winch was the real answer solidly 2 times.
Winch & a rear ARB ~= e-locker conversion parts.
Sounds like more effort than it is worth to retrofit factory lockers to a non e locker axle. Wait till you find a factory locked truck or go with an aftermarket solution.
It isn't that bad. And especially worth it if you find a very clean non-locked rig. The knob can cost 3-4k if the seller knows what it is.. being open to adding the stuff later allows budgeting, changing plans (if decide on ARB/Harrop/open), and a MUCH broader array of clean interior/exterior and service records.. which are arguably more important for ending up with a solid truck.
thanks guys.. I like the idea of only doing the rear locker. I really spent a lot off time trying to find one with factory lockers but they were either a beat up, rusted out or way out of my budget. I found a 97 that rust free and has been well taken care of, it's in better physical shape than my 2012 f350!.. I couldn't beat the price. I just need to adress the front seat and recharge the ac..
the truck has a recently replaced radiator and the phh was done at that time about a year ago.. it was done professionally except the cooling system was filled with green anti freeze.. is this bad to leave in at this point? or should i flush it out? it's been in since the new radiator (factory).
I have read so much crap about this is better than that and so on it made my head hurt! I get cars in the shop every week with no antifreeze (rust), green, orange, pink, red and of course blue. Blue is rarely seen on the shelf these days, and orange is the normal colour for extended life (organic). Nowadays it is about toxins (local fisheries for example) and water hardness specific to your region. I have just the two on the shelf Red or Green, if a vehicle needs topping up with orange we just use some 'life extender'. When the red and green debate was raging on, I spent a considerable time reading the contents of my stock, and bar colour they were pretty much the same product EXCEPT, the red should be used where the water hardness is known to be at a low level, but even that has been changed now.
In Spain antifreeze now comes ready mixed, in red or green. When topping up you use the appropriate colour, if replacing for example water pump you put in whatever is nearest period. It is already mixed with distilled water so the correct amount of phosphate and corrosion inhibitors has been added. You can choose the 'start to freeze' protection, from -5 C through to -50 c, again in whatever colour you choose.
Think region, and then think colour, or use distilled water with either and sleep well.
regards
Dave
thanks! it was in my searching for a fj80 where I thought having green anti freeze in was a no no... in some adds the sellers were making a point to mention that " nothing but toyota red anti - freeze used In this rig" and "always serviced with genuine Toyota parts down to the anti freeze " even they guy who sold me mine said he was pissed when he saw green coolant in the resevoir. lol.. so I guess the stuff is probably more expensive than your average gallon of Peak. I'm sure water pumps don't care what color they're pumping!..
If they did the switch properly green stuff is FINE. That is, if they flushed every drop of red out and ran clean water through it for a while before adding green.
Some even prefer green due to it being more likely to be available in a random parts store in the middle of nowhere.
That is the main reason I switched. Cost is a secondary factor.. a gallon of red is $40 or more over the counter.
Savvy sellers could even dump the properly installed green and pour red coolant in there (without flushing) to give the impression of a truck that has been meticulously maintained. Needless to say this is far worse than a truck happily running green coolant for 100k miles.
if you are going to move from red, green is probably what you should run, and change it as the pH buffers wear out.. not orange or yellow. Generally these were designed for newer systems than the equipment being used when our trucks were built. not that that stuff won't work.. it just isn't designed to work as well in that specific environment.
Either way.. once again, this has been covered literally dozens of times elsewhere.
thanks bloc .. I'm not sure if all the red was properly flushed when the radiator was installed a year ago. let's say the mechanic just removed the radiator and hoses including the phh and replaced all new parts and filled with green coolant. so what red would be left in the block and heat core never got flushed.. how bad could that be? is red and green like mixing oil and water? sorry to keep asking same questions you guys .. I check the FAQ and I'm sure it's there, but couldn't find exactly what I was searching for. remember that I just got it yesterday so I'm like a kid in a candy shop! I got the urge to start spending money and definitely getting it to 100% .
I changed to green 12 years ago and never looked back. No issues since (or before, for that matter). I drain and fill every couple of years.
@MachineBob Don't sweat it, if you are handy with a screw driver pull the bottom hose, remove the rad cap, then with the ignition on move the heater control to HOT, then switch off the ignition and the stepper motor will keep the heater valve open. Now release one of the heater hoses on the bulkhead and stick a hose in it. Flush it through and refill with whatever colour takes your fancy, but use distilled water and don't forget the expansion tank, then call it done. If we assume the previous work did not flush through it will now be fine. Typical AF inhibitors last around three years. if you are not good with the spanners when it goes in for a service tell them what to do.
regards
Dave
