Getting abusive already? Sounds like you're losing an argument.
Quite simple. Because when you drop below cruising rpm (like on a hill) you want full torque available. That needs full boost.
It's necessary offroad as well as having a positive effect on fuel economy.
So toyota continues to get it wrong with all their diesels then huh? All the ones I've driven get full boost before 2000rpm.
The answer to that question is quite clear on this subject.
your "theory" needs some more research since you are wrong. when you are climbing a hill you drop a gear and the rpm goes up creating more torque and more boost... if you are already producing full boost at 2000 rpm WHY would there be any more boost available below the cruising rpm? buddy, back to the drawing with load board for you.
oh God of turbos, rpm does not relate to boost, load relates to boost. try it out someday AWAY from your desk.
i have yet to see a stock toyota produce full boost at 2000 rpm unless it is under load. your statement is missing this important fact.
under load you can be creating 14 lbs of boost at 1500 rpm and with no load (ie cruising down the highway) 6 lbs of boost at 3500 rpm... you NEED load to create boost.
i agree, the answer is very clear on this subject. you are shoot BS again.
. It should have said 1HZ in respect of both...
