1FZFE non-serviced "bushing" resolution
Texas
Website
www.peopleschoiceins.com
This is a very good thing for those of you with a !FZFE, needing or wanting an overhaul. Since Toyota does not service this bushing, and evidently would rather sell you a $4,000 block (according to CDan), it looks like there is another way to resolve the issue.
Our friend in Mass. (bjowett) had a bushing made that he says he didn't feel comfotable with. I have looked into having my old one refurbished, with little interest from would be venders.
Now there emerges a nice touch of mechanical inginuity from a guy who makes new bushings in the block. He comes highly recommended from several sources.
Have any of you tried this?
I am taking my engine block to him next week.
I'll let you all know how it turns out.
Dan Taylor
Not quite 4 thouand bucks but close. A short block lists for $3,387.49 and a bare block lists for $2,634.22.
Looking forward to hearing the result. Don't drop that thing on your foot....
DougM
DougM
Don't worry, one advantage of being big is being able to lift heavy objects.
The advantage of living as long as I have is knowing when to use an engine crane.;)
So, just out of morbid curiosity, how much is "our" price for a short block?
$2,710.00
cruiserdan said:
$2,710.00
Used diesel blocks aren't even that cheap. IMO, awesome!
I feel stupid... what bushing are you talking about?
There is a bushing pressed into the face of the engine block that the oil pump idler gear runs in. That bushing is not serviced seprately from the block.
concretejungle said:
I think you misunderstood the quote. That's a shortblock, not a bare block he's given you the price for.
-Spike
We shall now refer to as bushiing 2710, or simply - B2710, since Toyota has no part number for it.
How obsurd is this? To build this awsome vehicle and not service a part that must be manufatured for them by someone.
Makes me wonder what third world Asian country has a thatch roof factory making them, or used to.
A skilled machinist should have no problem making a replacement bushing.
If I were to do it, and I am not a skilled machinist, my first step would be to remove existing bushing and measure diameter of hole in block. Outside diameter of bushing needs to be slightly larger to permit a press fit. Machinery Handbook has look up tables to assist in determining the difference in size of the bushing OD and block ID to get a good fit. Don't even need the old bushing OD to be in good shape, but presumably, if it is, can just measure the old bushing oD and duplicate.
Second step is to measure OD of shaft, determine desired clearance between bushing and shaft. Turn bushing outer diameter to finished size. Bore inner diameter slightly undersize. Install bushing in block and measure ID after installation. The reason to measure after installation is because it will likely tighten up in ID a bit after being pressed in to the block. Calculate amount of ID to remove to get to final desired ID. Remove and finish machining. All of the work can be done on a lathe.
With an adjustable reamer I expect the final ID sizing could be accomplished first time around with the bushing installed in the block with no need to remove for a second operation.
I'd hope an expert machinist could get the job done correctly without having the block on hand as long as accurate block bore and shaft dimensions are supplied. Of course, by providing the block to the machinist then he is responsible for all measurements and ensuring the goodness of the final fit - definite advantage to doing that.
-Spike
Yes, i was wrong, again. For some reason i glanced up at one price and then thought he quoted a higher price as a joke.
landtank said:
The only reason I can see for that bushing not to be serviceable is if it was machined in place at the factory. I have no idea if that's the case or if it's even plausible on an engine block but I have run into similar circumstances before on precision devices.
Rick,
The B2710 is a bushing pressed into the block during the block assembly process.
I'm taking the engine to my guy in Houston Thursday. I'm going to strike a deal with him and together we will patent the B2710 and sell them for $500 each, paid in advance. Or maybe $50, depending on how charitable I feel after I get some in my little hot hand.:grinpimp:
DTaylor,
Was the bushing in your block hosed up?
As I remember, Robbie first discovered this issue with the non-serviceable bushing when he had a 1FZ-FE block boiled out a few years ago. I don't remember what they did to "fix" the problem but it seemed the bushing was destroyed or lost in the process of boiling the block.
-B-
Is this bushing made of anything special - like oil impregnated brass or the like? I don't suppose a brifield needle bearing will fit here ....kidding!
