1FZFE Intake removal - real time help..
Texas
Website
www.peopleschoiceins.com
It looks like there is no other way to get this thing off accept to disconnect ALL the wiring harness connectors (including over the transfer case and the plugs in between) on that particular harness. The other end of the harness goes into the firewall and I presume to the ECU.
Anyone have a way around this?
Did you get the DVD that Idahodoug put together? I thought he had worked it out so you either didn't have to remove the harness or the intake manifold one.. can't remember.
:beer:
Rookie2
landtank said:
ID has you removing the head bolts and then rocking the head to the side to get to the rear bolts of the intake manifold. Then on reassembly just snugging up the bolts by feel without a torque wrench. I pulled the harness when I did mine.
Rick,
Were you the one that removed the harness by cutting a slit in one of the flanges of the manifold? Seems like I remember reading that was one approach to getting the harness or the intake out.
Someone cut the lower manifold supprt brace out. It was not Rick.
no cutting...
I'm just not a fan of cutting a manifold.....too much room for trouble there.
I guess I'll just get under the rig and undo those last two sub-harnesses that go to exhaust, xfer case, etc. Such a royal pain!
I was hoping for a better or easier way of getting the manifold completely off. I'm sending it out with the head to a machine shop for cleaning. They can vatt it at the same time they do the head, and hopefully get it really clean.
Thanks all!
BTW, did get Id's vid. He does not show pulling the intake all the way, just moving it over to the side. I want mine to be clean as new.
Too bad there isn't a harness upgrade with a connector that makes removing the intake manifold easier.
It’s lame,
but ya, I end up removing the glove box and ecu,
and pulling the harness from the fire wall out and thought the intake,
and leave the harness draped over the drivers side of the engine bay,
I pulled the harness from the ECU when I did my head. Royal PITA.
2nd time around I made a cut in the manifold between 2 cylinders (3 and 4 maybe?) It bolted down on both sides of the cut, so there is zero structural loss. I cut out just enough to squeeze the wire through.
Sometime later I had to get back in there, boy was I glad I had cut that! Made getting it out/in much quicker and easier, and removed the risk of breaking something in the harness.
I know it seems drastic, and at first I also opposed it, but now I'm glad I did it.
I just did the same thing as Seth-O, as he said it’s a pretty easy and effective mod.
Seems like there was a photo posted up years ago (the cutout section),
anyone have a recent photo for future reference?
Here is mine, post #7 and #10.
