1FZFE Dizzy Alignment
Hamilton Valley NSW
Hi Guys, just wondering if the rotor on the distributor should be at TDC when the two alignment marks on the end are aligned..
i know when i did the pulled my dizzy / o-ring - (asdie from marking the dizzy postion (scratch / sharpie) on the block.
was also cautious to note the rotor orientation -
so IIRC - with engine set at TDC - the rotor sits ~ 2 O'clock
when you pull it - it twists counter clockwise and moves to ~11 O'clock -
so the reverse follow - align the marks on the dizzy shaft - and insert back in with the rotor at 11'oclock
Bf
