You kick Google's a**. Might I trouble you for the length and notch placement, and perhaps the spring specs? (I'm seeing some aftermarket listing 98.1mm valve length; spring specs vary.)
That's impressive--and good to know they're likely still in spec at 237k. What I'm looking for is info that would allow me to figure out, for example, which (if any) of these are stock spec (link is to springs, ignore the text)...View attachment 3244918
Amazingly......all of mine were well withing 'spec' even at 316K miles.
View attachment 3244923View attachment 3244925
Because if you need aftermarket springs it is because you need higher spring rates. For example the seat pressure for that Supertech spring is 110lbs @1.43". Compared to 53lbs on the stock springs.That's impressive--and good to know they're likely still in spec at 237k. What I'm looking for is info that would allow me to figure out, for example, which (if any) of these are stock spec (link is to springs, ignore the text)...
Dual Valve Springs
Supertech Dual Valve Springs for aggressive cams and boosted, high-RPM builds. Inner and outer springs add pressure and damp harmonics to stop valve float.www.supertechperformance.com
And why are they all dual-spring?
Each set specs listed, for example, the
SPRK-H1002D-1FZ kit...
- Seat Pressure: 50 @ 36.20
- Open Pressure: 160 @ 11
- Max Lift: 14.00mm
- Coil Bind: 19.50mm
- Rate: 10
- Kit spring: SPR-H1002D
- Kit spring qty: 24
- Retainer: RET-H70/T1
- Retainer qty: 24
- Seat Locator: SEAT-H/N240
- InnSpr.ID: 15.50mm
- InnSpr.OD: 20.50mm
- OutSpr.ID: 21.85mm
- OutSpr.OD: 29.10mm
- Seat Locator qty: 24
Jeez, and that's the lowest-rated spring they have. How do you calculate that from the information provided above? Or do you just happen to know those springs?
Teach a man to calculate...50kg *2.2lbs/kg = 110lbs
36.20mm/ 25.4mm per inch = 1.43"
Sooo, no one makes such a thing? Because.Not mention what the open pressure would be. Good way to wear your cam lobes out faster.
If the OP isn't going to Supercharge the engine and then constantly flog it to 6 grand.....he doesn't need a have dual spring set up.
There are good reasons for dual springs.....but most don't apply to this engine (if not built for racing).
A proper dual spring set could be had and would offer longer life and reliability than the stock set up, but why? Stock springs seem to last over 300K and handle any reasonable engine rpm.
Sooo, no one makes such a thing? Because.![]()
