- Thread starter
- #41
Wow. Today marks 5 years with the 100 and nearly 346k miles. Somehow I managed to put 19k miles on it in 2020, so I have put exactly 100,000 miles on this cruiser in 5 years.
This last year was quite productive!
My solar install still allows room for the RTT on the 80/20 rack.
I used LED clearance lights for a trailer to complete the amber cargo lighting. Those little lights provide a huge amount of useful light.
I shoehorned the ARB CKMA12 compressor between the air filter box and second battery. The CH4x4 switch inside is just plain cool!
My wife and I did get out to Colorado in the fall for a week of lumbering around the Rockies.
Attempting to make the best out of diagnosing the pesky low RPM surging and stalling issue. In Kansas, our favorite color is Sunset.
The 5 years I've had with the Cruiser have been good. I have learned a lot, made some great connections and thanks to MUD, I feel like I can tackle anything on this rig. The Cruiser experience has been so good that my wife decided to trade her Subaru Outback for a 2016 200. I have also learned how awesome Partsouq is. How the heck do they get parts to me across the world faster than McGeorge can get them across the States?
My plans for 2021 include:
- Manual FM antenna "upgrade"
- Rust mitigation and slowing
- New tires (the Maxx have 40k miles on them and will need replaced at some point)
- Finally integrate the BenCC overhead switch panel
- Maybe a set of Owl Expedition sliders
- Possibly a snorkel with a pre filter on top
- Installed OME 2866 rear coil springs
- Installed (used) Wet Okole seat covers on the middle row
- Replaced Batteries Plus 27F battery with Advance Auto H7 AGM
- Built and Installed a voltage booster on the Alternator Sensing fuse
- Installed LRA 40 gallon replacement main fuel tank
- Replaced Rollover Valve
- Replaced Rollover Valve tube assembly
- Replaced Fuel Pump (Denso)
- Replaced Fuel Pump gasket
- Replaced Fuel Cap Assembly
- Installed Solar on 2nd battery
- Sealed sunroof with Eternabond RV Roof tape
- Rich Solar 100w flexible panel adhered to sunroof with 3M VHB tape
- Renogy Voyager Charge controller mounted to aluminum bracket behind passenger headlight
- 20amp circuit breaker between solar charge controller and 2nd battery
- Replaced cracked intake tube with a Tundra/Sequoia intake tube
- Installed Huracan tailgate storage lid
- Installed Raingler rear cargo net
- Removed failing SuperLift Truespeed speedometer calibrator
- Replaced Charcoal Canister
- Replaced purge valve and pressure sensor
- Replaced rear tail lights with (used) '04 tail lights
- Installed amber cargo lights in holes left in rear pillar trim from seatbelts
- Installed Front and Rear Z36 Powerstop Brake kit, rotors and pads
- Replaced 12v socket in rear power panel with ARB fridge socket and wire
- Installed CKMA12 ARB Air compressor under hood
- Power feed from AHC plug with jumped relay slot
- Switched via custom CH4x4 Toyota push button
- I spent October thru December chasing down a Low RPM surging and stalling problem
- Cleaned Crankshaft Position Sensor
- Cleaned Sensor electrical grounds as found in EWD
- Checked resistance of EVAP and Vapor Pressure VSV
- Checked that Pulse Damper screw pops up when running
- Checked that Air Filter was not plugged
- Checked and Retorqued Spark Plugs
- Checked for vacuum leaks with propane torch
- Checked that sensors and plugs are secure and tight
- Checked fuel pressure, found it was a little high
- Replaced Fuel Pressure Regulator with new Toyota
- Replaced TPS and Throttle Control motor with used parts that checked OK
- Replaced MAF with new Toyota
- Replaced EVAP VSV hose to the top of the throttle body with new Toyota
- Replaced downstream O2 Sensors (Denso)
- Cleaned EFI Fuse slot and replaced fuse
- Replaced ECU (used from Mauser)
- Inspected wire pins at ECU and discovered if Green/White wire (1 of 3 signal wires from MAF) is wiggled engine would die
- Removed Green/Wire wire pin from ECU plug, crimped female connector and reinstalled
- Programmed 2 new Master Keys with fob (aftermarket key with 4c chip) and OEM non remote key
- Replaced rear sombrero badge with a chrome one
