Yes, do the upper and lower trunion bearings . I've seen several go bad. The main axle bearings are so big they usually don't.
What year is your 80. Wiring putouts will vary in years.sooo reading through your build, I saw a dismantle of your factory harness which is exactly what I am planning on doing for my swap
I was wondering if you documented which wires to remove etc.... I have a couple excel sheets iv'e started for Point a to b, but havent really found anything of the sorts other going through the EWD's and going from there..... oh the tedious parts....
No, not much seat time at all. She went up on jack stands a few months ago so I could pull 3rd members for lockers. I got carried away with rebuilding the front-end, which has taken a lot longer than I anticipated. The front end is going to look purty fo sho! I should have it back together sometime after the new year. More info then...was just curious if you've been able to put in much seat time since the tune. Hows it running? How is that 6.0 on fuel?
