For Sale 1996 Lexus LX-450 - Great Build / Daily Driver / Off-Road / Rock Crawler - Stone Ridge, NY
New York & California
Website
www.rbfilms.com
SOLD - 07/28/2017
1996 Lexus LX-450 / Toyota Land Cruiser
Excellent Condition
4 Door Wagon / Sport Utility
Style: All Wheel Drive
Mileage: 201,562
VIN: JT6HJ88J6T0143252
Fuel Economy:
City 12/Hwy 14/Comb 13 MPG
Max Seating: 7
Doors: 4
Engine: 6-Cyl, 4.5 Liter Supercharged Engine
Drivetrain: 4WD
Transmission: Automatic
EPA Class: Sport Utility Vehicles
Body Style: Sport Utility
Country of Origin: Japan
Country of Assembly: Japan
Professionally Modified, Built & Maintained
Super Charged, Lifted & Loaded
Dual Hydraulic Winch, Dual Batteries, Air Compressor
Custom Bilstein Suspension, Lighting & More!
Dual Hydraulic 12K Winch / Dual Batteries
Comfortable Daily Driver Designed, Engineered & Built for
Rugged Use by Working Professionals & Off Road Enthusiasts
Fully Loaded with Top of the Line Upgraded
Heavy Duty Parts & Components
Everything Works! Excellent Condition!
310-310-5891 / rcasey@4x4northamerica.com
The Ultimate Escape Vehicle!
1996 Lexus LX-450 / Toyota Land Cruiser 80 Series
Modified for Serious Off-Road Use, Expedition Travel and Search & Rescue Services.
Professionally Designed, Engineered & Built by 4x4 North America, Inc.
Year - 1996
Model - Lexus LX-450
Engine - 4.5 Liter / FZJ80 - Supercharged
Fuel Type - Gas
Cylinders - 6
Drive - 4WD with Triple E-Lockers
Color - Champagne
VIN # - JT6HJ88J6T0143252
Mileage – 201,562
Condition - Excellent
Title – Clean
Meticulously designed, built and maintained by the owner of 4x4 North America, Inc. Supercharged Engine & Professionally Modified for Off Road, Expedition, Search & Rescue Service use. All brand-new parts, components and equipment professionally installed as listed below by 4x4 North America's Master Mechanic. Brand New 100% Leather Seating & Trim throughout upgraded and improved over OEM. Used Off-Road only once. 99.98% of the time used as daily driver by owner of company. Superior Craftsmanship and Attention to Detail Throughout. Excellent Condition.
• Purchased in Excellent Condition with 127,600 Miles
• Built & Modified to Current Specifications at 128,150 Miles
• Current Condition is Excellent and Mileage 201.562 Miles
• Estimated Engine Output with Engine Mods -- 325 HP / 385 Foot Pounds Torque
• New - Complete Upper Engine Rebuild including PM Head Gasket Modification
• New - Ported, Polished & Flow Optimized Heads & Blueprinted Valves
• New - Toyota OEM Supercharger
• New - Custom Off-Road Suspension Lift & Springs
• New - Bilstein 7100 Series / 5100 Series Custom Shocks with Custom Tuning
* Numerous Performance Upgrades & Vehicle Modifications as Listed Below
MODIFICATIONS BY 4x4 NORTH AMERICA, INC.
Toyota TRD Supercharger
ARB Bumper Front
Snorkel
Axle rebuild kit - front
Axle rebuild kit - rear
AC dryer skid plate
Differential locker skid plate
Hand throttle
CDL switch
Fog switch
HID switch
Transmission skid
Tie rod and drag link
Front 4.88 gears
Rear 4.88 gears
Front diff master kit
Rear diff master kit
Rear solid spacer
Front solid spacer
Sway bar links
Gen 2 caster plates
DC front shaft
DC Rear Shaft
Rear Lower control arms
Upper rear control arms
Pan-hard adjuster front
Pan-hard adjuster rear
HD sway bar mounts front
HD sway bar mounts rear
Blue fan clutch & syn oil
IBS dual battery system
IBS mounts
2 mill spec tire deflators
No loss tire caps x5
Puncture repair kit
Extreme aire magnum 12 volt compressor
150 amp relay
100 amp relay
125 psi switch
20' 4 gauge cable
1 way check valve
165 blow off valve
OBA switch
25' dot push to connect hose
2 gallon air tank
4 male 3/8 fittings
3 way t fitting
3 way t fitting swivel
bulk head fitting ¼”x 3/8 tubing
heat dissipation hose
90* brass fitting
12K mile marker hydro winch - Front
12K mile marker hydro winch - Rear
Joystick remote x 2
3 way solenoid valve
Interior winch control - (Custom)
Winch remote control - (Wireless)
Series 35 adapter kit
Hydro cooler Toyota
In-cab controller
MP super line XD 3/8x100 x2
MP rock guard 2
MP aluminum fair-lead front
MP aluminum fair-lead rear
Winch accessory kit 857
Sling hook connector link
Class 3 2' receive with ¾ shackle x2
Van best ¾ 62.700lb screw shackle x2
Dixon bate mounts x2
Hi-lift extreme jack 60”
Hi-lift jack off-road base
Hawk HPS front break pads
Hawk HPA REAR break pads
Fire extinguisher mount
Fire extinguisher
Chrome moly axles rear
DBA rotor front left
DBA rotor front right
DBA rotor rear left
DBA rotor rear right
Husky liners front
Husky liners rear
Intro-tech windshield snow shade
4x4 labs rear bumper
Steering Dampener
metal tech sliders
IPF 900xs HIDD x2
IPF rectangular headlight 184
IPF x91 HIR bulbs
IPFWF-3 wiring harness
IPF 2 light wiring harness
Killovac LEV200A4AnA relay (tyco) X2
Power steering pump
Extended break line front left
Extended break line front right
Extended break line rear
Sears platinum battery - Main
Sears platinum battery - Aux
Aux battery tray
ARB antenna mount
7 pin trailer plug
2 nato jerry cans
CB antenna
CB ham radio meter
Panavise cb/ scanner clips x4
Cell phone amp and antenna
35” Toyo Open Country II A/T x5
Powder coat rims x5
LT seat extenders x2
HD tie rod ends
Front sway bar drops
Rear bumpstop blocks
Rear sway bar brackets
Kenwood dnx 9140 nav system with I pod an sat radio
Toyota/Lexus wire harness amp
Kenwood mtg-10
Keenwood kca-ip301v
Kenwood ca-sr20v
Sirius connect sc-c1
Passport 9500ix gps radar laser detector
Toyota seat foam front seats
Wagongear tail gate storage system
FOR Custom Springs
Bilstein 7100 Series Shocks w/Custonm Valving
Yellow box spedo correction
1991 washer bottle bracket
1991 washer bottle
LT wb bracket
I-pad holder
Ram mount - cb setup
Ram mount - gps setup
Back up camera vtb 301 color
ARB bumper splash guard
Toyota oem cup holder
120mm cooling fan
120mm cooling fan thermal switch
Viper alarm 5902
Viper glass break sensor
Viper 12v back up battery
Viper digital tilt sensor
Air iq sat tracking
Lowrance hds-5 baja gps
Cargo D-Rings
Trail gear front axle armor
M2K - 270 Amp Alternator
ICOM 7000
Little Tarheel II - (HF Antenna 3.5 Mhz to 54 Mhz)
N2VZ TT-IC7000 - Turbo Tuner - (Backordred)
ICOM IC-SP22 - (External Speaker)
Comet-NCG HP-32FHN - VHF/UHF Antenna - (2M / 440)
Comet CMX-1
Magnum S-980 - AM / SSB - 10/11 Meter Radio
Cobra XL-500 - (Amplifier used for 10 Meters Only with Magnum XL-500 - Tuned for 200 PEP Maximum Output Legal Limit)
Uniden BCD-396T & BCD396XT - (APCO 25 Handheld Scanner Radio)
Austin Spectra Quad Band Scanner Antenna - (30-50, 150-174, 430,512, 806-896 Mhz)
Wilson Cell Phone Amplifier - Dual-Band 800 / 1900 Mhz Amplifier - (824-894 Mhz / 1850-1990 Mhz)
Wilson Cell Phone Antenna - Dual-Band 800 / 1900 Mhz Antenna - (824-894 Mhz / 1850-1990 Mhz)
$31,995
SOLD - 07/28/2017
lol. amen
I am not a used car salesman. These are my personal trucks!
