1995 obd2 compliant?
FOG TOWN->SF<-
im trying to buy and obd2 reader to measure engine temp, mpg, volts, ect (scangauge2).
My 1995 lc has a obd2 port in which I can plug in my computer and see everything that's going on.
My question is that the scangauge2 specifies that it only will work with a 1996 and newer. Before I take the $160 plunge, will it work with my 1995?
Also if anyone else can recommend maybe a Bluetooth version that works an Apple iPad/iPhone please advise the Bluetooth connector and app.
obd2 was introduced to the states in 95. It became mandatory in 96. you may have obd2 but you should wait for others to chime in!
If you have the port you have obd2. There's even some late 94 cars with it, I think.
Another option is to save $100 and get an Ultragauge.
For bluetooth, this device (available from many vendors with various names on it) seems to be the smallest, and mine works fine. as far as iphone (or android) is concerned it's just another elm device.
https://www.amazon.com/dp/B01894Q9QM/?tag=ihco-20
Or if you're in no hurry at all:
Auto Car ELM327 OBD2 V2.1 Bluetooth Diagnostic Interface Scanner OBD-II New
I like my Scangauge on my 95
I bought this bluetooth scanner, works great with the free torque app on my android phone.
Lower left side of steering wheel above the fuse panel.
full
One major problem with iOS devices is the lack of bluetooth serial support. I'm not sure if these adapters use a serial connection or something else.
Mine does not have that kind of port
Then you may not have OBD2. What year is your Landcruiser? What was the original country of use? They added them in the US spec trucks in 1995.
For iOS devices, you can use WiFi devices, instead of BlueTooth. For instance one like https://www.amazon.com/Veepeak-Scanner-Adapter-Diagnostic-Trouble/dp/B00WPW6BAE/?tag=ihco-20
Wifi
I have 2 different ones. One works great with iOS wifi and dashcommand and the other works great BT with Torque.
