1994 Factory Locker Value Question
Torrance, CA
Hey guys new to the forum and to the Toyota world. Current SUV is a 1990 Mitusbishi Montero and I'm looking to make a change to a Land Cruiser was hoping for some opinions.
A mutual friend is looking to sell his 1994 factory locked cruiser. Vehicle has 315,000 miles on it, body is straight, has been well cared for and has a ton of extra parts (too include some factory cloth seats!!!). Vehicle is currently leaking oil, engine still runs well and needs a new heater core. He was quoted by his mechanic (former Toyota Master Mechanic) that it would cost about $800 to just fix the oil leak (owner isn't sure where the leaks originated from off the top of his head) but he thinks the engine should be rebuilt at this point and that was quoted at about $3500-$3800 by his mechanic.
He hasn't done any research on the market and basically told me to do the research figure out what I think a fair price is and he'll give me a good deal. So this brings me to you guys, the 80 series market seems hard to read, this is pretty high mileage but it does have the factory lockers. What say you all the brain trust as to its value?
Appreciate everyone's time.
Pics will let many share their opinions much faster. Google search 80 series engine rebuilds. It will pull up ih8mud info on what this involves and $.
If the shop will do a complete rebuild with Toyota parts for $3500 have them do it and give you a 5 year+ warranty.
Buy the truck for $1800 and then pay to have that done. Specify OEM only.
It was well maintained and runs well, but, the engine should be rebuilt? This is contradictory. 315k really isn’t an impressive odometer reading these days.
What are the compression numbers?
Do a leak down test?
Does it use oil or expel visible smoke from the tail pipe ever?
Why does it need a heater core?
Fix the oil leaks and run it til it dies... an engine rebuild is a pretty heavy expense to consider a PM. Show some pictures of it for a fair price.
Value of truck should be 4000-5000 at the minimum.
parts alone are valued at around 4-5.
Now what someone would pay for it depends on lots of other personal factors.
So clearly I don't have enough information to get an accurate idea of the value. Personally knowing the owner I suspect it doesn't need a rebuild he's just the kind of guy that goes overboard with such things.
I ordered a Blackstone Labs test kit and sometime next week I'll go over and run a cylinder leak down, compression and coolant system test.
I'll report back with my findings.
I would start with the valve cover and work my way down to cure the leaks.
engine still runs well - from this comment, I would not "rebuild" the engine. Odds are its either the valve cover gasket or front engine pulley, or the plate with the o ring leaking, I'd fix these areas and if it runs good, enjoy another 100K on it.
and needs a new heater core - This I have read is a PITA to do, and requires ripping appart the whole dash.
Has lockers - value in my eyes
I am guessing fairly rust free.
Without pics and it needing work, 2K is the most I would fork over for it, that is if its not rusty.
If it is only leaking oil slowly, and the rig runs well, just add oil occasionally and run it. My rig has 350K on it and I take it out to the middle of nowhere (central / eastern Oregon) often. If it ain't broken...
Didn't I read somewhere on here that the "design" of the 1FZ was to be rebuilt every 300k km and could be rebuilt 3 times? So the life of the engine was estimated at 1.2M km. Or am I making that up?
I've read that number on multiple occasions myself.
Designed to be rebuilt every 180K miles? I find that extremely hard to believe.
