Build 1988 BJ74 “Number 1”
So living where I live we have to ship everything. Shipments take a long time as well…
So I decided to drive and get my parts 👍
My kind of place…
Picked up a rear main seal. Thanks @cruiseroutfit
Could you use a Speedi Sleeve on the rotating part the rear seal rubs against?
A leak similar to this is common on MGB’s and speedi sleeves are often used.
Is there a super seal of the right size like Marlin Crawler’s Eco Seal?
I don’t think it will need it. I think this is just a case of not using an OEM rear main, if that’s what the problem is.
I suppose it’s possible it’s the oil pan, but I don’t think so just from where it’s leaking.
I used some speedi’s on my pto shafts.
I’ve used them before, I just don’t think it’s needed. I had marginal luck with the speedi sleeve.
It didn’t leak for 50k miles, I think this is just a crappy non-OEM seal. Every other seal in the engines australia kit failed.
A lot of guesswork there mate. Why wouldn’t you fix the sump leak first? (The easier job)
My bell housing looked exactly like that and it was leaking from one bolt on the filter bracket mount, dripping onto the top edge of the oil pan and the turbulence from driving would blow the oil into the bell housing and create the exact same drip.
Yeah that’s the plan. The oil definitely can travel while driving so I’ve been watching it but nothing definitive so far.
The easier is the sump like you stated. Needs done either way. If that solves it, the we are good.
The only doubts I have is that if I pry back the bellhousing flywheel cover, the oil is smashed up in there. I “think” the only way for oil to get there is from the inside…but wind and pressure can do strange things
