1987 BJ70 ragtop mods ...
All factory locker diffs require clearance cuts for the shift fork when going into a non-lock housing. Top pinion 80 fronts require extensive modification to go into a non-lock housing.
Wayne's jig is pretty cool by the way.
Those 3rds are each from the rear an 80, yes. My understanding is that they'll fit in the front of a 60 (which is a full floater) if you make those cuts, but won't work in the semi-float rear that most 60s have. If you're lucky enough to have a FF in your rig, or can get one, then it'll fit if you make the cuts.
And get custom axle shafts with longer splines to accomodate the locking sleeves. This is the case for both the e-locker and the cable-locker.
Cool, thanks guys
thanks for the compliments guys, appreciated.
the jig makes the notch SOOOO easy to do and now i can do the notch in just a couple minutes with clean results instead of a mess of time and a "okay" job when completed.
i have one long spline front axle left in stock and i want to see if i can find a machine shop that will modify a few short spline front axles for me. there is no load on the splines when running open so strength won't be an issue but smooth operation will be a must.
later i will post up pics of the detailing.
cheers
I was thinking exactly the same thing. The longer splines simply provide a place to "park" the sleeve when the axle is unlocked. As long as there is enough material on the shaft to extend the splines I would think it would do just fine.
