- Location
- United States
1983 Fj43 For Sale in Miami.
(PS,PB,AC,5 SPEED,ROLL BAR & much More)
Asking $35,000
The Fj was recently Frame on Restored by "Clean Cruisers Of Miami"(Great local TLC shop). No lipstick here guys, truck was Restored the proper way not cutting corners. Looks good on pictures as well as if you were standing next to it.
The undercarriage is clean with no surprises. Runs goods and starts right up. Unlike other South American Fj's this one was inspected and serviced in the states by professionals. I can provide a list with all the repairs/maintenance's done and the shop owner's contact info if anyone is interested in customizing the truck.
I can send detailed pictures/videos if requested.
Interior:
Late model Luxury Dash. knobs and switches are present and operate:
Wipers slow/fast & wiper fluid spray operational
Choke, hazard, interior light, Digital clock (recently installed).
Cigarette lighter is present and works.
There's a JVS Cd-Am/Fm radio that works great with 2 speakers .
All gauges operate correctly with the exception of the voltage meter (stuck on 50). Holds engine temp on the cool side. Speedometer is in kilometers but easy to figure the conversion to miles.
Emergency brake light works and holds the vehicle stationary. 4wd lights works
Horn functions.
Gauges, dash, and dome lights all function.
Ac unit was re wired and fully serviced, blows cold air and fan works. Note: Doesn't have a heater but it can be installed at new owner expense.
-All of the above was inspected and addressed when needed attention.
Front seats and jump seats in stock charcoal-grey were recently reupholstered.
Front and Cargo mat are present, used but in good condition. Driver & passenger floorboards and cargo bed are in great condition.Sun visors (new) and rear view mirror are functional.
New 5-speed shift knob.
Pedal pads for brake, clutch and gas in good condition.
Glove box is clean and comes with a new inspection light.
Driver & passenger windows roll up and down properly.
Seat belts for both fronting seats and both jump seats(set of 4 seat belts)present and function properly.
Rubber weather stripping around the front doors are new.
Has a factory Roll cage built in the hard top.
Exterior:
Body is straight.
Recently painted factory color code 681.
Turn signal, emergency, tail, head, brake, reverse, side marker and license lights are present and function properly.
All emblems front, side and rear are present.
New Hood latches, windshield latches, side mirrors and Antenna.
Kick vents function properly with new weather stripping.
Spare tire swings together with Rear Door making an easy access to the cargo area. Rear step is present.
Set of 5 New Tires BF GOODRICH 31x10.50R15
A/T KO2.
Late model Factory steel wheels.
Stock front bumper and rear bumperettes straight and solid.
Engine, Transmission, Frame, etc..:
Stock 2F engine, runs very well. Compression test was performed and showing between 128-130 psi.
Asin locking hubs rotate smoothly.
Has a 5 speed H55f transmission that works great. Transfer shifts into H2, H4 and L4 with no issues.
Five-speed & reverse shift smoothly through all gears.
Clutch and brake pedals are strong. Vehicle accelerates,stops and Steering is straight.
It has factory Power Steering and Factory front Disc brakes.
4 new shocks, exhaust and battery. Fresh Tune up (oil change, spark plugs, etc etc)
Odometer Is Not Working (stuck on 279.000km)
NOTE: I tried my best to make this truck a safe and reliable Fj (Daily Driver) yet at a reasonable price.
Truck is sold as is, therefore I encourage you to inspect the truck before making offers. I will provide a clear Florida title & Bill of Sale to the new owner.
Cheers
Asking $35,000
Interior:
Horn functions.
Exterior:
Body is straight.
A/T KO2.
Cheers
