1981 Fj45 Flagstaff AZ USA
Do you like the green rims or do you think they should be OEM grey steelies
  • I like the way it is--Green!
    Votes: 1 4.2%
  • I think grey steelies would look better
    Votes: 23 95.8%
  • Total voters
    24
Flagstaff AZ
I finally finished my frame off restoration which took two years with a little time off here and there. I am looking forward to my next project. That is why I am sad to say I am putting my girl up for sale. I imported this beautiful Fj45 from Australia approximately three years ago. Only drove it around the block once or twice then dove into it. Total tear down, bead blasted the frame then powder coated. All axles torn down new seals and bearings with all new transfer case seals . I had the body acid dipped primed and painted. I added a brand new bed from Awl TEQ (as seen here on Mudd Forum). I assembled the bed and I must say it turned out fantastic, thanks to Awl_TEQ craftsmanship. :cheers: Pretty much stock except for front shackle reverse, Old man-emu 3 1/2 lift, DUI distributor. Every nut, bolt, screw, washer, pin, clip cleaned blasted or replaced. Too much to list! I will post finished picks to see rebuild album leave your Email and I will forward them to you. $45K
Tire size???? By the looks of the undercarriage picture, they are BFGs. My guess is that they are 33 x 10.5 MT.
