So the list of things to do currently are:
1. Build a fan shroud. I ordered a sheet of metal from a guy today and we are going to cut/bend/weld something that resembles a fan shroud. Hopefully it will help keep the temps down.
Quickly looking over your build, you mentioned a Taurus fan. I too have a gen one truck and used the shroud that came with the fan. After the cutting it fit like it was made for the truck.
The input shaft seal blew out of the steering box. If it would have blown out AFTER the event then it would not have been a big deal because I am going to do the spring swap and will go with a high steer setup with an IFS box. Of course, things never work out that way. Also, there is some special tool that you have to have to remove a stake nut off the end of the box which we don't have. (Shocking I know, but this is a 32 yr old truck...) So, I am searching to see if I can find one at a junk yard. Worst case scenario I guess I will attempt to drive it with no P/S but I already know that is going to be nearly impossible. It def won't be any fun. Anyone happen to have one laying around from a part-out?
