- Thread starter
- #281
Anybody have any experience with electric fans on the 22RE? Will the "Taurus" fan work? I'm trying to decide what I'm going to do. The mechanical fan I have in there is much closer to the radiator. There was no way to use the original shroud. It was hitting the a/c compressor and wasn't really lined up with the fan correctly. Anyway, I'm thinking either a. remove the mechanical fan and run a big electric (will still need to figure out some kind of shroud) or b. run 1 or 2 small electric pusher fans on the condenser. The pusher fans will supply enough cooling (I think) but space is limited. Everything is already pretty crammed in there. Any opinions or experiences welcomed.
when I get home. This weekend I'm going to try to pick up some parts a pull-a-part. Looking for A/C controls, A/C switch (on/off, apparently won't work without it), some different A/C lines (going to try to run a pickup condenser instead of the double type from the Runner), and possibly some A/C vents to try to work something out for the center vents. I'm also going to try to get the ducts finished on Sunday, install the speedo cable from the Runner (not sure if it's good or not), and get the radio and GPS wired back up. I also need to wire the horn and wiper motor.
