1976 FJ40 2F
Wnichester UK
Good afternoon folks, just registered on here having purchased the above vehicle, lots of information here and I look forward to learning more about the mechanics of the vehicle.
It is in excellent condition and my primary concern is the temperature gauge. I have replaced the sender unit and the needle moves as far as the first indicator (C) then stops. The gauge works as it rises if I earth it out on the chassis.
Obviously a b 42.litre petrol engine will get pretty warm so I would not want it overheating. Is the gauge sitting in the right place or have I missed something?
Many thanks
Paul.
Welcome. We need pictures.
Your temperature gauge reads the same as mine (I too have a '76 FJ40 w/ 2F). I use an inferred thermometer and when it has been warmed up and driven I get a reading of 175*F (needle at first indicator). I have a 180* thermostat.
Paul- BJ40green has posted lots of good info on gauges. You can type his username in: posted by member, to distill search results.
Thanks for the response, so if the the engine gets excessively warm, I guess the needle would continue to rise? Perhaps I need to check it when it's warm to be on the safe side?
As suggested by @samatulich test it with an inferred gun. I wouldn't spend another moment worrying about this or spending any $$ on parts until you determine if you even have a heating/cooling problem.
Once you have the gun, then you can make an accurate assessment and fix the problem.
I second this. The temperature gauge in my old CJ-7 spiked once and said that I was overheating. Somewhat trusting the gauge I walked a mile to the nearest auto store and bought an infrared thermometer just to walk back and find out that the engine was at normal operating temp and the gauge broke.
