Thank you.You did that yourself! Nice work, mydogpea.
I've gone off the DGAS sheet. The mixture screws are 1 turn out.
That's not an adjustment. It holds the (idle mixture jet?) iirc and should be turned snug.
one screw out total? or off base line of 1 turn? so your out 2 turns?
if you are out 1 turn total...go out to 2.5 and report back
the vac nipple off the carb is ported vac...at idle it will be low to none...when the throttle is opened the vac increase....advancing the dizzy
there will be no vac off the dizzy....only from the port nipple on the carb...
1) so you timed with the vac line off the dizzy and you pluged it when adjusting the timing ....correct?
YEP.
2) manifold vac is full vac at idle...like the nipple on post #45 should be...what is the vac there?
At idle (500-ish rpm), with the butterflies closed in the carb, the vacuum gauge read a solid 20psi at this port.
3) where is you idle now?
Right about 550rpm
4) hows it run now? same? dies or not?
do you have an oem dizzy and coil to put in to exclude the ignition as being a culprit...just incase the po did something wacky to the dui?
is the dui a store bought? do you know? or a junkie find HEI by PO?
