SOLD 1972 FJ40
Karis Finland
$5500 no engine
$8125.96 w/engine new price for added parts
As of today (3-25-2019) what money I spend on the 40, the price will go up that amount.
1972 FJ40 originally from California. The doors I have had in dry storage since early 80's. Some surface rust but no rusted out places.
Engine, fresh rebuilt 1974 F.5, Crank is .010 on both rods and mains. Bore is 030. Rods were resized. New Toyota cam gear. New Mellings stock replacement cam. Head has all new GM LS valves, springs etc. Head has been surfaced .010. Block has been decked. 020. Engine was run about 30 seconds twice. 3rd time I tried to start it. It was locked up. 2 main bearings were installed wrong. All damage was contained in the rear main journal. No damage to the block. Crank was sent out and polished. New rod and main bearing were installed. Everything else looked new. Engine was run about 30 minutes at 2000 rpm to break the cam in. Fresh Lucas Classic 10w-30 oil and a Baldwin filter was installed after that. Flywheel was resurfaced, new clutch assembly installed. GM 100 amp alternator. Later clutch fan. 79 style valve cover, has screw in oil filler cap.
Stock exhaust system, needs gaskets in it. AFI tbi fuel injection conversion. In tank fuel pump, VSS, 3FE dist and a custom chip.
Front axle 1977 disc brake axle has been rebuilt. New trunion bearings. Marlin crawler inner axle seals. Later stub axles and Aisin lockouts installed.
Rear axle rebuilt, new axle bearings and seals. Has 3.70 gears 1978 4 speed transmission and a November 1973 transfer case, has the more desirable lower ratio.
Have mini truck power steering conversion parts. Needs to be installed. 75-76 roll bar, stock 72 front seat. No jump seats.
New brakes shoes and wheel cylinders on the rear. Front has rebuilt calipers and new pads.
New rebuild kit for the center steering arm. New Alcan springs. They are about 2" lift. New Monroe gas magnum 60 shocks.
New cam soon to be installed.
Wait...you're not actually selling your build are you? That had an engine installed so I'm guessing not. So what all are you selling for $5500? Sorry for the rambling. Just hoping to still follow along with your build.
Everything is for sale.
Yes, selling what I was building. Engine is for sale also.
Ever heard the phrase, the straw that broke the camels back? Well it happened yesterday. No need to get into details on a public forum.
Sorry, man. Oh yeah that's happened to me before. I had a '71 Jimmy I worked on for 10 years then just one day sold the thing. Been missing working on a project ever since. I've been lurking on this forum for about a year now, reading and learning. I've been looking for a project that was priced right, had most of the body work done and had some interesting history to it. I can handle mechanical/e/electrical stuff. I wont be able to drop 5500 till October, 8 weeks from now. If you still have it I am definitely interested. Here's a picture of me on the last day I sold my Jimmy.
I’m interested in the list of parts too
Almost complete. The only thing I can think of that's missing is the jump seats. Rear sill needs outer ends fixed, this is the only rust in it. Everything else is rust free. Lots of new parts still in the Toyota package. Has 4 speed trans and 3 speed T-case. 3.70 pumpkins installed and extra 4.11's. Both axles have been rebuilt. Front axle has disc brakes. AFI tbi conversion with VSS.
Builds - My Project, I get to retire when its finished.
$8000. Price reduction bump. Clear title in my name. Ordered new wheel cylinders and clutch slave cylinder. Will get all that installed this week. Give me a couple days to bolt everything together. Should be driveable on a trailer.
Hardtop sides original paint.
