Wanted 1969 FJ40-Durango, CO
Status
Not open for further replies.
  1. 40 Series
Looking for 10 pin connector to my instrument panel for my 1969 FJ40. Thanks. Jim
@JVZii dude is the FJ40 cluster master!
@ToyotaMatt has new ones that are very nice.
@ToyotaMatt
Hello mr. Jimster sir .... :)
i offer this plug , crimp , and play KIT form needed parts solution for you ....
- i had the original BLACK YAZAKI black barrel connector reproduced over a Decade ago , in mass numbers ,
- the Quality is A+ both the Nylon UV rated housings and the SOLID Brass Terminals ,
- i include several extra for practice and goofs we all including me can and do make once in a while ,
- all the terminal bays are clearly numbers 1-12 same as OEM , and the Orientation KEY way ensures proper FIT FORM and Period correct function !
- includes the LATER 3pin connector also , you will not need , so u have it for a spare else ware ...
- My KIT form gig here , ALSO NOW Includes qty x 2 OEM Genuine YAZAKI FACTORY 30A amp meter RING Terminals rubber insulator boots , these were IN-FACT factory installed DAY 1 PLANT A11 assembly line in JAPAN , starting in 1973 - Later ...
- you have 2 paths to choose from below , please PM me if you have any questions or i can further assist
thanks for your support ... :)
kindly
matt ..
Kevos 37: I would like to but one of your cluster connectors. The one on the right of the pic would be great! I also need the pin connectors with wires for the light switch, the hazard switch and the turn signal wires on my steering column. Do you have these? Much Thanks. Jim
Status
