- Thread starter
- #41
What did you use to blast your parts? Media and equipment?
The blaster is a " little Blaster" by blast it all as earlier mentioned and the media is 70 grit - as hopefully the attached will show
I have 6 clip, riveted stock rims. I am not a tire guy. I like the Yokohamas. Any ideas as to whether this particular Yoko will work with the rims I have?
.Seat cover color needed! I need help. I am trying to find a vinyl close to OEM and I am coming up short. "Coral" is what is usually used to ID these on MUD but I have yet to find a manufacturer that offers the color or (to me) anything close (pics make it appear almost orange). The options appear to be Aatlas1x, SOR or a local upholstery shop.The first is great and the second is functional. My best price seems to be the latter-particularly if I can find a suitable material/color. Although my preference is OEM close, I am open to suggestions and solicit your comments or suggestions for a sharp match to a Dune Beige. Thanks!!!!!!!!!
Notwithstanding the quote, "better to be quiet and thought a fool than to open your mouth and remove all doubt..." I'll ask where would the starter handle bracket(s) be mounted on a 66? I didn't come across any "unused holes" on top of the passenger wheel well nor do I recall any in the compartment under the drivers seat where the jack brackets are located. If helpful, I'll be glad to photo and measure with mic's the specs for these brackets-let me know.Looking closer , they appear to fit the smaller jack rods as is usually the case . Looks like rod size is a bit bigger than the hood hinge pins in the pic , bummer . The starter handle brackets would be bigger , almost the outside of hinge diameter . I have a late model thinner clip coming , will have to adjust the metal thickness to replace the early ones . Appreciate the help !
Sarge
